Hello, I love the concept of your devices, However, my router does not respond to wifi no matter how many times I try factory reset, Neither does it respond on a direct cable to either ports , having set DHCP or fixed IP 192.168.8.2 for example.
Two green lights are showing and the red light blinks if I play with the lan cables ,.
