GL-AR300M16 ver4.3.22 Can't install kmod-usb-storage
I have a GL-AR300M16 with firmware 4.3.22, and i can't use my usb pendrive so i tried to install kmod-usb-storage-extras and got the message:
Collected errors:
  • pkg_hash_check_unresolved: cannot find dependency kernel (= 5.10.176-1-5c9be91b90bda5403fe3a7c4e8ddb26f) for kmod-usb-storage
  • pkg_hash_fetch_best_installation_candidate: Packages for kmod-usb-storage found, but incompatible with the architectures configured
  • pkg_hash_check_unresolved: cannot find dependency kernel (= 5.10.176-1-5c9be91b90bda5403fe3a7c4e8ddb26f) for kmod-usb-storage-extras
  • pkg_hash_fetch_best_installation_candidate: Packages for kmod-usb-storage-extras found, but incompatible with the architectures configured
  • opkg_install_cmd: Cannot install package kmod-usb-storage-extras.
So i tried to update kernel but i only have version
5.10.176-1-bcd3946ab03a646ea54610bdb available and no more updates.
I have made the mistake of uninstalling kmod-usb-storage and now i can't install it, cause i have the following message:
Collected errors:
  • opkg_install_cmd: Cannot install package kmod-usb-storage.
So it also depends from the same kernel.
Another thing is that when i do an opkg update é get the foolowing errors :
I think i've found the problem the 4.3.22 update wasn't perfectly applied, cause the date of compile time showed as 2024-12-05 instead of 2024-12-18 as it shows now after i've made a local upgrade to 4.3.22 . Now i've been able to install kmod-usb-storage and kmod-usb-storage-extras and other packages, and the opkg errors don't show anymore.
