GL-AR300MD will it has an external antenna?
Will you have external antenna version ? If not can we make one by our self ?
Do you have a battery version ?
No. We don’t have external antenna version and battery version.
The reason is that, it need 3 antennas, two for 2.4G and one for 5G. We have no space to put these antennas. Of course you can use external antenna by yourself. You can use for the 5G module because it has a uFL connector.
What if I want to make it battery version by myself. Is it possible ? Can you guide me ?
If you have a battery you can connect to it. But you need to take care of charging circuit which is not realistic.
