Hello, GL-AR750 support poe?
What’s poe injector it need?
which port must be connected to power the GL-AR750 with ethernet?
AR750 has two versions. You have to specify the PoE version when you buy.
The PoE use 48V 802.3af standard injector. Do not use 24V injector, which will not work.
PoE is on WAN port only.
sorry where can I buy AR750 with poe version?
