Having a strange issue. I cannot seem to access the set-up menu to make adjustments. I tried multiple times to re-boot and still cannot access the menu. Weird thing the router does work as a router using the LAN connection, but using the 192.168.8.1 address, nothing happens. Help…
You need to check what is your pc’s IP address when you are connected to it.
Thanks for your feedback. The IP address is : 192.168.1.117
Mark
Did you plug the Internet cable to the LAN port?
Apparently you should get a 192.168.8.x IP address. Check out the video guide
Hey, thanks for all your help here. I’m 99% sure I followed all these steps in the last week, but with no positive outcome. Today, all sorted!
Thanks again!
Mark
