Hi all,
Newbie here. I purchased this device to simply use it as a file share server. I have Verizon hotspot that I carry with me when i travel with my kids. What I wanted to do was simply piggyback off the Verizon MiFi to share the contents of the sd card or hard drive.
I connected the device selected wds and joined the Verizon MiFi. no problem. the issue is once I connect my laptop to the Verizon MiFi I cannot ping the ar750 or access the shared resources.
to gain access to the ar 750 I have to manually assign a static ip to my laptops wifi card to be able to log back into the ar750. Once I I log in, everything looks normal. Not sure what im doing wrong here.
I have set up repeaters before and never had these much problems, usually, when you add a repeater, devices attached to both aps see each other but not with the ar750.
I feel like there is some kind of routing issue or gateway issue.
I had version 2.27 and upgrded to the latest 2.272 in hopes to fix this issue with no luck
Can any one help?
thanks
