Hello, I bought a GL-AR750 Travel Router. It works and has the actual firmware. How could I read the the files on the micro card? I use an iPhone. I installed the file sharing and enabled to read over lan and wan. I tried to connect with smb://192.168.8.1 but it does not work: could not connect. The same I tried with my mac, it does also not work. The card is formatted with NTFS.
