I’ve just bought a GL-AR750 which I am using in router mode. I live on a boat, and want to use the AR750 to connect two laptops to each other (for file-sharing) and to the marina wifi. I also want to run aria2 and AriaNg on it. I updated to the latest firmware, 3.027, as soon as I got it.
The wifi here has been a bit flakey the past month, and the connection frequently drops and has to reconnect.
I’m currently less than 10m from the nearest AP, which is on a 3m or 4m high post, about 1m from the end of my boat. My boat is 12m long, and I’m siting in the middle of it. I’m guessing the APs are MikroTik or something - I don’t know how many they have, but the marina is over 320m x 150m, and the wifi is obviously a professional installation.
On my MacBook the wifi is sometimes fine for days at a time, but the GL-AR750 seems more sensitive to it, and at best it’s staying connected for only 20 or 30 minutes at a time right now. Mostly the AR750 is losing the connection to the wifi every couple of minutes, perhaps staying connected as long as 5 or 10 minutes, and it’s infuriating.
Where can I find logs in order to diagnose this better, please?
http://192.168.8.1/cgi-bin/luci/admin/status/syslog looks useful, but I can’t grep it or filter it, and I can’t copy and paste it. I’ve tried using find, looking for syslog and ‘log’ but am not finding it.
I can ssh into the box, which is great, but everything in /var/log/ and /var/log/cores/ is 2 days old.
Thanks in advance for any help,
Stroller.
