so I'm sitting in front of a GL-AR750 with Firmware 4.3.18 and I'm pulling my hairs out, honestly.
I did a reset of the router via the web intererface -> System -> Reset firmware to make sure I'm in a clean state.
I have two devices connected to the router via the LAN ports (the WAN port is not connected).
I can connect to the router from both devices.
I can ping both devices from the router (after connecting to the router via SSH).
I can ping the router from both devices.
I can NOT get a SSH connection between the two devices.
I can NOT send a ping between the two devices, no matter the direction.
What is going on here?
I did not change anything on the router after the reset, the only thing I did was set a password for the web interface.
Thanks already!
admon
April 1, 2025, 12:10pm
2
What IP addresses do they have? DHCP enabled?
Yeah, IP addresses are assigned via DHCP in 192.168.8.0/24.
If I connect one of the devices via WiFi, it works just as expected.
It's only an issue when both are connected via LAN ports.
edit: It also works fine if I reconfigure the WAN-port as LAN-port and plug one of the devices into the WAN-port.
So, I contacted support regarding this issue and they confirmed it.
They also provided me with a solution which I'll share here, should anyone else need it:
ssh into the router (ssh root@192.168.8.1 )
edit /etc/config/network with your favorite text editor
make the following changes
system
Closed
September 30, 2025, 7:57am
5
