*Deimos1994:*
Hello, it's my first issue here.
My hardware: ALFA Network W502U… / R36
Problem: USB port doesn't work.
It works on openwrt-15.05, but does not work on lede-17.01.4 & openwrt-18.06.1.
I tried all I could find on google, but no successes.
All bellow done using: OpenWrt 18.06.1, r7258-5eb055306f
I don't know how to do diagnostics properly, but here is what I already did:
root@OpenWrt:~# lsusb -t
Segmentation fault
unable to initialize libusb: -99
root@OpenWrt:~# opkg list-installed | grep usb
kmod-usb-core - 4.14.63-1
kmod-usb-ehci - 4.14.63-1
kmod-usb-storage - 4.14.63-1
kmod-usb-uhci - 4.14.63-1
kmod-usb2 - 4.14.63-1
libusb-1.0 - 1.0.22-1
usbutils - 007-9
Segmentation fault
root@OpenWrt:~#
Maybe this can help:
root@OpenWrt:~# dmesg
[ 0.000000] Linux version 4.14.63 ([email protected]) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7102-3f3a2c9)) #0 Thu Aug 16 07:51:15 20 18
[ 0.000000] SoC Type: Ralink RT3350 id:1 rev:2
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 0001964c (MIPS 24KEc)
[ 0.000000] MIPS: machine is ALFA Networks W502U
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 byt es
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000001ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000001ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000001ffffff]
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] free_area_init_node: node 0, pgdat 803eaeb0, node_mem_map 8100004 0
[ 0.000000] Normal zone: 64 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000] random: get_random_bytes called from 0x803ee72c with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jff s2
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Writing ErrCtl register=00065de0
[ 0.000000] Readback ErrCtl register=00065de0
[ 0.000000] Memory: 27964K/32768K available (3419K kernel code, 172K rwdata, 424K rodata, 200K init, 210K bss, 4804K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 256
[ 0.000000] CPU Clock: 320MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_i dle_ns: 11945377789 ns
[ 0.000019] sched_clock: 32 bits at 160MHz, resolution 6ns, wraps every 13421 772796ns
[ 0.007898] Calibrating delay loop... 212.58 BogoMIPS (lpj=1062912)
[ 0.094000] pid_max: default: 32768 minimum: 301
[ 0.099003] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.105607] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.122218] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.132051] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.138273] pinctrl core: initialized pinctrl subsystem
[ 0.146792] NET: Registered protocol family 16
[ 0.160804] Can't analyze schedule() prologue at 80352ab0
[ 0.213659] rt2880_gpio 10000600.gpio: registering 24 gpios
[ 0.219347] rt2880_gpio 10000600.gpio: registering 24 irq handlers
[ 0.236791] clocksource: Switched to clocksource MIPS
[ 0.244339] NET: Registered protocol family 2
[ 0.250848] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.257890] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.264159] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.270926] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.276710] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.283640] NET: Registered protocol family 1
[ 0.295590] rt-timer 10000100.timer: maximum frequency is 3255Hz
[ 0.303509] Crashlog allocated RAM at address 0x1f00000
[ 0.313920] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.332748] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.338615] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORIT Y) (c) 2001-2006 Red Hat, Inc.
[ 0.380470] io scheduler noop registered
[ 0.384301] io scheduler deadline registered (default)
[ 0.390769] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.403784] console [ttyS0] disabled
[ 0.407515] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 6666666) is a Palmchip BK-3103
[ 0.417412] console [ttyS0] enabled
[ 0.424364] bootconsole [early0] disabled
[ 0.433566] cacheinfo: Failed to find cpu0 device node
[ 0.438911] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.446463] 1f000000.cfi: Found 1 x16 devices at 0x0 in 16-bit bank. Manufact urer ID 0x0000c2 Chip ID 0x0022cb
[ 0.456743] Amd/Fujitsu Extended Query Table at 0x0040
[ 0.462002] Amd/Fujitsu Extended Query version 1.1.
[ 0.467163] number of CFI chips: 1
[ 0.488329] 4 fixed-partitions partitions found on MTD device 1f000000.cfi
[ 0.495300] Creating 4 MTD partitions on "1f000000.cfi":
[ 0.500855] 0x000000000000-0x000000030000 : "u-boot"
[ 0.508096] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.515425] 0x000000040000-0x000000050000 : "factory"
[ 0.522776] 0x000000050000-0x000000800000 : "firmware"
[ 0.542321] 2 uimage-fw partitions found on MTD device firmware
[ 0.548525] 0x000000050000-0x00000019e790 : "kernel"
[ 0.555519] 0x00000019e790-0x000000800000 : "rootfs"
[ 0.562562] mtd: device 5 (rootfs) set to be root filesystem
[ 0.568501] 1 squashfs-split partitions found on MTD device rootfs
[ 0.574802] 0x0000003c0000-0x000000800000 : "rootfs_data"
[ 0.583610] libphy: Fixed MDIO Bus: probed
[ 0.591353] rt3050-esw 10110000.esw: link changed 0x01
[ 0.609880] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0 100000, irq 5
[ 0.619526] rt2880_wdt 10000120.watchdog: Initialized
[ 0.627610] NET: Registered protocol family 10
[ 0.642865] Segment Routing with IPv6
[ 0.646978] NET: Registered protocol family 17
[ 0.651634] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.664823] 8021q: 802.1Q VLAN Support v1.8
[ 0.681284] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.691413] Freeing unused kernel memory: 200K
[ 0.695918] This architecture does not have kernel memory protection.
[ 1.619412] init: Console is alive
[ 1.623555] init: - watchdog -
[ 2.396830] random: fast init done
[ 2.722565] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.890829] kmodloader: done loading kernel modules from /etc/modules-boot.d/ *
[ 2.910041] init: - preinit -
[ 4.382680] 8021q: adding VLAN 0 to HW filter on device eth0
[ 4.672961] random: procd: uninitialized urandom read (4 bytes read)
[ 8.115618] jffs2: notice: (324) jffs2_build_xattr_subsystem: complete buildi ng xattr subsystem, 4 of xdatum (3 unchecked, 1 orphan) and 32 of xref (1 dead, 0 orphan) found.
[ 8.134525] mount_root: switching to jffs2 overlay
[ 8.190331] overlayfs: upper fs does not support tmpfile.
[ 8.206092] urandom-seed: Seeding with /etc/urandom.seed
[ 8.442557] procd: - early -
[ 8.445811] procd: - watchdog -
[ 9.256926] procd: - watchdog -
[ 9.261065] procd: - ubus -
[ 9.415882] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.427196] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.434866] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.444910] procd: - init -
[ 10.363541] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.493682] usbcore: registered new interface driver usbfs
[ 10.499804] usbcore: registered new interface driver hub
[ 10.505524] usbcore: registered new device driver usb
[ 10.542139] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.640628] SCSI subsystem initialized
[ 10.679912] ehci-platform: EHCI generic platform driver
[ 10.696730] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 10.732456] Loading modules backported from Linux version wt-2017-11-01-0-gfe 248fc2c180
[ 10.740697] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
[ 10.756445] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.782367] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[ 10.925284] usbcore: registered new interface driver usb-storage
[ 10.976219] xt_time: kernel timezone is -0000
[ 11.101389] PPP generic driver version 2.4.2
[ 11.112322] NET: Registered protocol family 24
[ 11.161352] usbcore: registered new interface driver rtl8187
[ 11.203176] rt2800_wmac 10180000.wmac: loaded eeprom from mtd device "factory "
[ 11.210710] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 2872, rev 0200 d etected
[ 11.218641] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
[ 11.227089] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 11.399574] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.487575] urandom_read: 5 callbacks suppressed
[ 13.487592] random: jshn: uninitialized urandom read (4 bytes read)
[ 31.034969] 8021q: adding VLAN 0 to HW filter on device eth0
[ 31.128839] br-lan: port 1(eth0.1) entered blocking state
[ 31.134327] br-lan: port 1(eth0.1) entered disabled state
[ 31.140711] device eth0.1 entered promiscuous mode
[ 31.145584] device eth0 entered promiscuous mode
[ 31.247802] br-lan: port 1(eth0.1) entered blocking state
[ 31.253292] br-lan: port 1(eth0.1) entered forwarding state
[ 31.259544] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 32.027373] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 39.584842] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 39.605642] br-lan: port 2(wlan0) entered blocking state
[ 39.611182] br-lan: port 2(wlan0) entered disabled state
[ 39.617552] device wlan0 entered promiscuous mode
[ 40.719820] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 40.726761] br-lan: port 2(wlan0) entered blocking state
[ 40.732315] br-lan: port 2(wlan0) entered forwarding state
[ 76.772365] random: crng init done
[ 83.214660] do_page_fault(): sending SIGSEGV to lsusb for invalid read access from 00000000
[ 83.223256] epc = 00406f3d in lsusb[400000+11000]
[ 83.228069] ra = 00406f19 in lsusb[400000+11000]
[ 1235.373340] do_page_fault(): sending SIGSEGV to lsusb for invalid read access from 00000000
[ 1235.381999] epc = 00406f3d in lsusb[400000+11000]
[ 1235.386822] ra = 00406f19 in lsusb[400000+11000]
