The GL-AR750 POE is 48 VDC ?
yes
Why does the product page for GL-AR750 not mention anything about PoE if it supports it? I see it’s an ordering option, I wouldn’t have known this if I hadn’t gone to the store. There should be a line “PoE: optional” in the specs.
Thanks for the suggestions. Will add ASAP.
