Hi folks
I have a brand new AR750 running stock Firmware 2.27 which I upgraded from 2.263 using the GUI immediately after undboxing.
I then immediately installed Wireguard which is running better than I expected.
To get into the router I go straight into LEDE by going to http://192.168.X.X/cgi-bin/luci/admin (therefore completely bypassing the stock GUI).
Heres my problem:
Under WIRELESS OVERVIEW (http://192.168.X.X/cgi-bin/luci/admin/network/wireless)
Generic MAC80211 802.11nac (radio0)
Channel: 48 (5.240 GHz) | Bitrate: 6 Mbit/s
71% SSID: XXXX | Mode: Mast
Under ASSOCIATED STATIONS
RX Rate / TX Rate
-60 / -102 dBm
400.0 Mbit/s, 40MHz, VHT-MCS 9, VHT-NSS 2, Short GI
6.0 Mbit/s, 20MHz
What’s ging on please??
When I run internet speed test I get 20Mbps on a 50Mbps line and streaming HD is absolutely fine… my wifi is set to my country standard and the AR750 is only 5gHZ signal on the channel.
