I just updated the firmware to 4.3.2 beta on the AR750S-EXT and noticed that Zerotier has disappeared from the Admin Panel (Applications). Is there any way to revert to a prior version where Zerotier is available. I believe the prior firmware I was using with zerotier available was dated 4-14-2023 v4.2.1.
I also tried to install the zerotier add-in (v1.10.3-1) but it failed to install and returned with an error message below:
Collected errors:
- pkg_hash_check_unresolved: cannot find dependency libstdcpp6 for zerotier
- pkg_hash_fetch_best_installation_candidate: Packages for zerotier found, but incompatible with the architectures configured
- opkg_install_cmd: Cannot install package zerotier.
