I bought a GL-AR750S as my existing router doesn’t allow me to install a VPN. So I thought I would buy this product and then I can use a VPN over wifi.
I’ve gone through the setup, I can’t get connected to the internet whether I try a direct cable from my router to the GL-AR750S or over wifi.
Adding the CyberGhost VPN software looks pretty straightforward, but I just can’t seem to use the GL-AR750S as a basic repeater at the moment.
Is there a really simple guide somewhere for dumb arses like me?
