Hello
I just got an GL-AR750S-EXT and the load is too high, router heats up a lot. I’m using default configuration.
Image:
Is my unit defective?
Thanks
Hello
Image:
Thanks
Did you enable real time traffic statistics? Or something else?
You can ssh to the router and use top to check the processes?
