Hello
can anyone add the 4G Systems XSStick W1208 to 3G/4G Modem or Tethering ?
It doesn´t show up in the Router GL-AR750S-Ext.
Cant bring it to Work.Someone can help me with this ?
Thanks
Hello
Thanks
Can you give some logs when plugged in this modem?
ssh to the router and use the following command
dmesg
logread
ls /dev/
Your file only contains some kernel log which does not contains message when you insert the dongle.
Can you get the full log after you plug in the modem?
[ 1680.637648] usb 1-1: USB disconnect, device number 2
[ 1715.128494] usb 1-1: new high-speed USB device number 3 using ehci-platform
[ 1715.344322] usb 1-1: New USB device found, idVendor=2fd4, idProduct=9aff
[ 1715.351389] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1715.358792] usb 1-1: Product: USB Modem
[ 1715.362772] usb 1-1: Manufacturer: USB Modem
[ 1715.386365] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 1715.401736] scsi host1: usb-storage 1-1:1.0
[ 1716.474316] scsi 1:0:0:0: CD-ROM USBModem Disk 2.31 PQ: 0 ANSI: 2
GL-AR750S-Log-New.zip (7.3 KB)
You need to execute the 3 command one by one. Not type them in one line.
dmesg
logread
ls /dev/
Any way, can you pls try type the following command and check if this works to make the device as a modem. Try unplug and plug your modem one more time if it does not take effect immediately.
echo 9aff 2fd4 >/sys/bus/usb-serial/drivers/option1/new_id
GL-AR750S-Full-Log.zip (12.1 KB)
I try
Not shown as a modem, then I pulled the stick and connected it again.
Nothing happend.
The Stick is flashing green all the time.
Can you try
echo 2fd4 9aff >/sys/bus/usb-serial/drivers/option1/new_id
