One antenna on my glAR750 is much stiffer than the other… does anybody notice the same issue?
I thought that after some use the stiff antenna might loosen up a bit but it’s still very stiff.
I’m wondering if it’s worth taking the thing apart to see if there is a manufacturing defect or something blocking the movement.
Also wondering if the antenna is properly connected or not.
Johnex
2
The antennas are connected via a short pigtail to an internal u.FL connector
If there are some variations in the plastic of the antenna they could have different levels of stiffness.
They are attached like this:
You can open the case and wedge something between the tabs to make the antenna have more friction, or remove it, bend the tabs outwards a little
