I’m running 3.105 and am trying to port forward RDP from the wan to Raspberry Pis on my internal wireless network. For the record, I can connect to the RPis using RDP just fine from my internal network, so all IP addresses and listening ports are correctly configured.
Editing the Firewall in the non-advanced part of the gl.inet admin panel was not successful. That is, adding conventional forwarding rules accomplished nothing.
I then went to the advanced settings under Network/Interfaces/WAN and turned on the bridge and included eth0.2 (lan, wan,wan6) and both wireless interfaces (2.4G and 5G) (no guests). That allowed forwarding to work for a short time (I could scan the public IP of the router and see the RDP port open, and of course a remote desktop connection worked fine); however, this setup did not survive a reboot of the router. That is, after a router reboot, the settings all looked the same, but port forwarding stopped and scans of the public IP again showed no ports open. I have verified through the reboot that the public IP address has not changed.
After pulling my hair out for a long time trying different settings, I worried that I might have made things worse, so I reverted the firmware to factory settings and started again, but this time not even creating the bridge works – there is no evidence that port forwarding works at all.
I would like to confirm: to accomplish what I want to accomplish, I need only create the entries in the non-admin firewall interface, and then turn on bridging, is this correct? Is there anything else I need to be doing? Should I revert to a specific earlier version of firmware? Any hints at all?
I’m happy to provide any screenshots needed to help troubleshoot.
