my router keeps disconnecting in repeater mode with master network:
Sun May 10 03:44:52 2020 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Sun May 10 03:44:52 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Sun May 10 03:44:52 2020 kern.info kernel: [44334.247100] wlan-sta: deauthenticating from 88:f8:72:0c:ae:2a by local choice (Reason: 3=DEAUTH_LEAVING)
Sun May 10 03:44:53 2020 daemon.notice netifd: wwan (32347): udhcpc: received SIGTERM
Sun May 10 03:45:40 2020 daemon.warn dnsmasq[3092]: no servers found in /tmp/resolv.conf.auto, will retry
Sun May 10 03:45:40 2020 daemon.notice netifd: Interface ‘wwan’ is disabled
Sun May 10 03:45:57 2020 user.info : [ 1470] gl-wifi-core>> wifi(radio) scan failed. Use phy to scan…
Sun May 10 03:45:57 2020 kern.info kernel: [44398.551007] IPv6: ADDRCONF(NETDEV_UP): tmp.phy0: link is not ready
Sun May 10 03:45:57 2020 kern.info kernel: [44398.565725] IPv6: ADDRCONF(NETDEV_UP): tmp.phy0: link is not ready
Sun May 10 03:46:03 2020 user.info : [ 1476] gl-wifi-core>> wifi(phy) scan failed. Use wlan to scan
Sun May 10 03:46:09 2020 kern.info kernel: [44411.338497] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Sun May 10 03:46:09 2020 kern.info kernel: [44411.371099] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Sun May 10 03:46:11 2020 user.info : [ 2607] gl-wifi-core>> bIsStaEnabled=1
Sun May 10 03:46:12 2020 daemon.notice netifd: radio1 (23094): Successfully initialized wpa_supplicant
Sun May 10 03:46:13 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Sun May 10 03:46:13 2020 kern.info kernel: [44415.296346] wlan-sta: authenticate with 88:f8:72:0c:ae:2a
Sun May 10 03:46:13 2020 kern.info kernel: [44415.314760] wlan-sta: send auth to 88:f8:72:0c:ae:2a (try 1/3)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.423527] wlan-sta: send auth to 88:f8:72:0c:ae:2a (try 2/3)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.533498] wlan-sta: send auth to 88:f8:72:0c:ae:2a (try 3/3)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.541150] wlan-sta: authenticated
Sun May 10 03:46:14 2020 kern.info kernel: [44415.553564] wlan-sta: associate with 88:f8:72:0c:ae:2a (try 1/3)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.663493] wlan-sta: associate with 88:f8:72:0c:ae:2a (try 2/3)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.673813] wlan-sta: RX AssocResp from 88:f8:72:0c:ae:2a (capab=0x431 status=0 aid=58)
Sun May 10 03:46:14 2020 kern.info kernel: [44415.682371] wlan-sta: associated
I tried all firmware versions available. Right now I’m on 3.104.
I’m struggling with it for 2 weeks now… keeps driving me crazy.
What else do you need? It’s default config, so I have no idea why IPv6 is enabled.
Fri Jun 19 12:24:36 2020 daemon.notice netifd: Network device 'wlan-sta' link is down
Fri Jun 19 12:24:36 2020 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Fri Jun 19 12:24:36 2020 kern.info kernel: [346966.355981] wlan-sta: deauthenticating from 50:04:b8:56:92:62 by local choice (Reason: 3=DEAUTH_LEAVING)
Fri Jun 19 12:24:36 2020 daemon.notice netifd: wwan (13487): udhcpc: received SIGTERM
Fri Jun 19 12:25:18 2020 daemon.warn dnsmasq[2638]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Jun 19 12:25:18 2020 daemon.notice netifd: Interface 'wwan' is disabled
Fri Jun 19 12:25:34 2020 kern.info kernel: [347024.556309] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Fri Jun 19 12:25:34 2020 kern.info kernel: [347024.580432] IPv6: ADDRCONF(NETDEV_UP): tmp.radio1: link is not ready
Fri Jun 19 12:25:36 2020 user.info : [ 2607] gl-wifi-core>> bIsStaEnabled=1
Fri Jun 19 12:25:37 2020 daemon.notice netifd: radio1 (30249): Successfully initialized wpa_supplicant
Fri Jun 19 12:25:37 2020 daemon.notice netifd: Interface 'wwan' is enabled
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.523972] wlan-sta: authenticate with 50:04:b8:56:92:62
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.542232] wlan-sta: send auth to 50:04:b8:56:92:62 (try 1/3)
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.558011] wlan-sta: authenticated
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.604425] wlan-sta: associate with 50:04:b8:56:92:62 (try 1/3)
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.614852] wlan-sta: RX AssocResp from 50:04:b8:56:92:62 (capab=0x411 status=0 aid=1)
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.623199] wlan-sta: AP has invalid WMM params (AIFSN=1 for ACI 0), will use 2
Fri Jun 19 12:25:38 2020 kern.info kernel: [347028.631022] wlan-sta: associated
Fri Jun 19 12:25:38 2020 daemon.notice netifd: Network device 'wlan-sta' link is up
Fri Jun 19 12:25:38 2020 daemon.notice netifd: Interface 'wwan' has link connectivity
Fri Jun 19 12:25:38 2020 daemon.notice netifd: Interface 'wwan' is setting up now
Fri Jun 19 12:25:39 2020 daemon.notice netifd: wwan (30440): udhcpc: started, v1.28.3
Fri Jun 19 12:25:39 2020 daemon.notice netifd: wwan (30440): udhcpc: sending discover
Fri Jun 19 12:25:42 2020 daemon.notice netifd: wwan (30440): udhcpc: sending discover
Fri Jun 19 12:25:42 2020 daemon.notice netifd: wwan (30440): udhcpc: sending select for 192.168.8.101
Fri Jun 19 12:25:42 2020 daemon.notice netifd: wwan (30440): udhcpc: lease of 192.168.8.101 obtained, lease time 86400
Fri Jun 19 12:25:42 2020 daemon.notice netifd: Interface 'wwan' is now up
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: reading /tmp/resolv.conf.auto
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain test
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain onion
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain localhost
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain invalid
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain bind
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using local addresses only for domain lan
Fri Jun 19 12:25:42 2020 daemon.info dnsmasq[2638]: using nameserver 192.168.8.1#53
Fri Jun 19 12:25:45 2020 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
What are using for power? I had very similar issues, but they seem to have been resolved by switching to a different USB power supply. Specifically, I switched to a canakit Raspberry Pi 3 adapter.
