I am so exhausted and tired by my GLInet experience and frankly, I am about to trash both this and my Beryl and never look back or recommend your devices again.
I can no longer connect to 2.4Ghz. Yes, it is enabled in settings. Yes, it was working until recently. Yes I have the latest firmware you have available. Yes I have tried resetting it. Yes I have tried changing the channel, the bands, the SSID, the wifi mode type and any other setting. I have tried moving my two LAN connections to different ports. There is no USB device attached which caused me problems until I learned this device BREAKS if you try to use a USB 3.0 device.
YES I am sure the clients list shows the 2.4Ghz device for 20 seconds until they drop off and nothing can connect to 2.4 EVER AGAIN UNTIL IT REBOOTS AND I REPEAT THIS SAME CYCLE OVER AGAIN.
I have the latest firmware:
Version4.7.0
Firmware Typerelease8
Update Time2025-03-19 08:46:18 (UTC+00:00)
It has been working, albeit constantly requiring reboots and other nonsense that I shouldn’t have to deal with on any router.
REGARDLESS OF WHAT I DO, WHEN THE ROUTER STARTS UP, 2.4GHZ DIES AND STOPS APPEARING ON ANY DEVICE”S WIFI LIST. IT IS ESSENTIALLY GONE AFTER BOOTUP.
WHAT INFORMATION DO YOU NEED FROM ME TO FIGURE OUT WTF IS WRONG WITH THIS DEVICE I PAID TOO MUCH MONEY FOR?
APPARENTLY, if I disconnect every one of my LAN connections, 2.4ghz starts working again.
It doesn’t matter which LAN port. I have multiple PCs with their own network cables and if any of them are connected to any port, 2.4ghz does not work.
Mon Nov 24 00:11:00 2025 cron.err crond[4054]: USER root pid 15178 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:11:00 2025 cron.err crond[4054]: USER root pid 15179 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:11:24 2025 daemon.info hostapd: wlan1: STA 40:9c:a7:62:43:70 IEEE 802.11: authenticated
Mon Nov 24 00:11:24 2025 daemon.notice hostapd: wlan1: STA-OPMODE-N_SS-CHANGED 40:9c:a7:62:43:70 2
Mon Nov 24 00:11:24 2025 daemon.info hostapd: wlan1: STA 40:9c:a7:62:43:70 IEEE 802.11: associated (aid 1)
Mon Nov 24 00:11:24 2025 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 40:9c:a7:62:43:70 auth_alg=open
Mon Nov 24 00:11:24 2025 daemon.info hostapd: wlan1: STA 40:9c:a7:62:43:70 RADIUS: starting accounting session 9898ABBAF7F4A424
Mon Nov 24 00:11:24 2025 daemon.info hostapd: wlan1: STA 40:9c:a7:62:43:70 WPA: pairwise key handshake completed (RSN)
Mon Nov 24 00:11:26 2025 daemon.info dnsmasq-dhcp[6320]: DHCPREQUEST(br-lan) 192.168.1.5 40:9c:a7:62:43:70
Mon Nov 24 00:11:26 2025 daemon.info dnsmasq-dhcp[6320]: DHCPACK(br-lan) 192.168.1.5 40:9c:a7:62:43:70 APOLLO
Mon Nov 24 00:12:00 2025 cron.err crond[4054]: USER root pid 15828 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:12:00 2025 cron.err crond[4054]: USER root pid 15829 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:12:00 2025 cron.err crond[4054]: USER root pid 15830 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:12:00 2025 cron.err crond[4054]: USER root pid 15831 cmd . /lib/functions/modem.sh;modem_net_monitor
Mon Nov 24 00:13:00 2025 cron.err crond[4054]: USER root pid 16465 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:13:00 2025 cron.err crond[4054]: USER root pid 16466 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:13:00 2025 cron.err crond[4054]: USER root pid 16467 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:14:00 2025 cron.err crond[4054]: USER root pid 17117 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:14:00 2025 cron.err crond[4054]: USER root pid 17118 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:14:00 2025 cron.err crond[4054]: USER root pid 17119 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:14:00 2025 cron.err crond[4054]: USER root pid 17120 cmd . /lib/functions/modem.sh;modem_net_monitor
Mon Nov 24 00:15:00 2025 cron.err crond[4054]: USER root pid 17784 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:15:00 2025 cron.err crond[4054]: USER root pid 17785 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:15:00 2025 cron.err crond[4054]: USER root pid 17786 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:16:00 2025 cron.err crond[4054]: USER root pid 18430 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:16:00 2025 cron.err crond[4054]: USER root pid 18431 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:16:00 2025 cron.err crond[4054]: USER root pid 18432 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:16:00 2025 cron.err crond[4054]: USER root pid 18433 cmd . /lib/functions/modem.sh;modem_net_monitor
Mon Nov 24 00:17:00 2025 cron.err crond[4054]: USER root pid 19092 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:17:00 2025 cron.err crond[4054]: USER root pid 19093 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:17:00 2025 cron.err crond[4054]: USER root pid 19095 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:18:00 2025 cron.err crond[4054]: USER root pid 19764 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 24 00:18:00 2025 cron.err crond[4054]: USER root pid 19765 cmd . /lib/functions/modem.sh;check_ip
Mon Nov 24 00:18:00 2025 cron.err crond[4054]: USER root pid 19766 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Mon Nov 24 00:18:00 2025 cron.err crond[4054]: USER root pid 19767 cmd . /lib/functions/modem.sh;modem_net_monitor
Mon Nov 24 00:18:01 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED 1c:3b:f3:15:20:e6
Mon Nov 24 00:18:01 2025 daemon.info dnsmasq-dhcp[6320]: DHCPRELEASE(br-guest) 10.0.1.77 1c:3b:f3:15:20:e6
Mon Nov 24 00:18:01 2025 daemon.info hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: disassociated
Mon Nov 24 00:18:02 2025 daemon.notice hostapd: Station 1c:3b:f3:15:20:e6 trying to disassociate, but it is not associated
Mon Nov 24 00:18:03 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:04 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:04 2025 daemon.info dnsmasq-dhcp[6320]: DHCPRELEASE(br-guest) 10.0.1.43 cc:32:e5:1a:e9:2d
Mon Nov 24 00:18:04 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED cc:32:e5:1a:e9:2d
Mon Nov 24 00:18:04 2025 daemon.info hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: disassociated
Mon Nov 24 00:18:04 2025 daemon.notice hostapd: Station cc:32:e5:1a:e9:2d trying to disassociate, but it is not associated
Mon Nov 24 00:18:05 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:06 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:06 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:07 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:08 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:08 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:09 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:09 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:10 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:10 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:11 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:12 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:12 2025 daemon.err smbd[19945]: [2025/11/24 00:18:12.976157, 0] ../../source3/smbd/msdfs.c:158(parse_dfs_path_strict)
Mon Nov 24 00:18:12 2025 daemon.err smbd[19945]: parse_dfs_path_strict: Hostname router.lan is not ours.
Mon Nov 24 00:18:13 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:13 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:14 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:15 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:16 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:16 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:17 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:17 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:18 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:18 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:19 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:19 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:20 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:20 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:21 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:21 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:22 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:22 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:23 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:23 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:24 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:24 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:25 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:25 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:26 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:26 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:27 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:28 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:28 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:29 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:29 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:30 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:31 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:31 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:32 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:32 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:33 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:33 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:34 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:34 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:35 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:36 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:36 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:37 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:37 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:38 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:38 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:39 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:40 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:41 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:42 2025 daemon.notice hostapd: wlan0-1: STA 1c:3b:f3:15:20:e6 IEEE 802.11: did not acknowledge authentication response
Mon Nov 24 00:18:42 2025 daemon.notice hostapd: wlan0-1: STA cc:32:e5:1a:e9:2d IEEE 802.11: did not acknowledge authentication response
This error log looks similar to USB 3.0 interference, but it seems that, in your case, the interference is coming from LAN devices.
Please try connecting your LAN devices one at a time to identify the source of the interference.
If possible, try using a different Ethernet cable too.
If you have an unmanaged switch, try placing it between the AX1800 and the LAN device and see if it helps or not.
