GL-AX1800 constant restart
  • Which router (which model?) are you using?
    • GL-AX1800
  • Which firmware version is in use?
    • Version - 4.6.4 Firmware Type - release1
  • How is your router connected to the Internet?
    • The router is connect to the ethernet port on the wall via cable. The ethernet port on the wall feeds back to the central point known as National Broadband Network (NBN) Fibre to the Premises (FTTP) box, something used in Australia.
  • Which DNS server do you use? (The local one of your ISP? AdGuard Home? Another one?)
    • the local one
  • Do you use DHCP or static IP addresses?
    • DHCP
The router would randomly restart and the attached is a copy of my log that I managed to export before everything was wiped. I noticed that is something in the crash log this time but I don't have the technical knowledge to decipher the logs to understand where the issue is.
Help is greatly appreciated. :smiley:
logread.tar (152 KB)
Seems to be an issue with the Wi-Fi driver.
What kind of devices connect to your Wi-Fi? Any IoT or special ones?
The devices that are connected are smartphones, laptops, PC, robot vacuum cleaner, android TV box (rarely use) and a chromecast (also rarely use). Other than these, no special ones are connected.
