New user purchased the Spitz installed now having the following problems:
Parameters: Cellular only with T-Mobile Sim Firmware: Version 4.3.5 Manual setup of TTL and HL 64 and 255.
Software reboot: Cellular connection does not reconnect until i pull the barrel connector. Then it slowly re-connects.
VPN Clients: Using VPN Unlimited with both wireguard or open vpn: Each reboot and even after pulling A/C power cannot reconnect after startup.
OPENVPN: CONNECTS BUT THEN IT STOPS AND RECONNECTS:
“Mon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: Joining mDNS multicast group on interface ovpnclient.IPv6 with address fe80::6da2:5874:265e:eb3f.\nMon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: New relevant interface ovpnclient.IPv6 for mDNS.\nMon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: Registering new address record for fe80::6da2:5874:265e:eb3f on ovpnclient.*.\nMon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: Joining mDNS multicast group on interface ovpnclient.IPv4 with address 10.200.0.78.\nMon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: New relevant interface ovpnclient.IPv4 for mDNS.\nMon Jul 24 05:23:49 2023 daemon.info avahi-daemon[5249]: Registering new address record for 10.200.0.78 on ovpnclient.IPv4.\nMon Jul 24 05:23:49 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now up\nMon Jul 24 05:23:49 2023 daemon.notice netifd: Network device ‘ovpnclient’ link is up\nMon Jul 24 05:23:49 2023 daemon.notice netifd: ovpnclient (8769): route: SIOCDELRT: No such process\nMon Jul 24 05:23:49 2023 daemon.notice netifd: ovpnclient (8769): route: SIOCDELRT: No such process\nMon Jul 24 05:23:50 2023 user.notice mwan3[9541]: Execute ifup event on interface ovpnclient (ovpnclient)\nMon Jul 24 05:23:50 2023 user.notice mwan3[9541]: Starting tracker on interface ovpnclient (ovpnclient)\nMon Jul 24 05:23:51 2023 daemon.notice ovpnclient[8769]: Initialization Sequence Completed\nMon Jul 24 05:23:52 2023 user.notice firewall: Reloading firewall due to ifup of ovpnclient (ovpnclient)\nMon Jul 24 05:23:58 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #638 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\nMon Jul 24 05:24:06 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #2912 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\nMon Jul 24 05:24:14 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #5075 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\nMon Jul 24 05:24:15 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #5084 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\nMon Jul 24 05:24:16 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #5106 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\nMon Jul 24 05:24:17 2023 daemon.err ovpnclient[8769]: AEAD Decrypt error: bad packet ID (may be a replay): [ #5126 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings\n”
