It shows it is DE version.
Is it normal?
Thanks.
Hi,Where did you buy the AXT1800? If you are in Europe, showing DE is normal.
Hong Kong.
It did not show any country code.
It had started showing “DE” since last beta firmware upgrade.
This is a new feature of 4.2 firmware. It only shows the country code written in the factory. It will not affect your use.
