Hi!
Version 4.7.0 generally has speed issues.
I almost called my ISP thinking there was a problem, but then I remembered the issues started right after the update.
I have a 1 Gbps uplink, and the router is connected via cable to the modem.
After the update, speeds wouldn’t go above 200 Mbps, even with a wired connection to the router.
Removing /etc/hotplug.d/net/40-no-gro didn’t help.
I rolled back to 4.6.11 and everything went back to normal -- speeds are back to ~1 Gbps.
Could you please let me know if any work is being done to address this issue in upcoming releases?
Hi!
Honestly, I haven't checked - is this a new parameter in 4.7?
In 4.6.11, I don't see such a parameter in the menu.
Also, I read in the manual: "When Network acceleration is enabled, the following functions will not work properly: Client Speed and Traffic Statistics, Client Speed Limit."
But the Client Speed Limit function is important for me.
BTW, for the GL-ATX1800 there is no 4.7.2 version available, only 4.7.0.
I don't understand because as far as I can remember (1 year with Gl-iNet) I've allways had this choice in the submenu in Network menu at the end
V4.3.17
