GL-AXT1800 - Print from a Secure VPN Network to a unsecure Network
Hallo,
I bought the router GL-AXT1800 with the ip address 192.168.8.1. This is installed behind a “Speedport 3” router. This is connected to the Internet and uses the address range 192.168.3.1. The GL-AXT1800 has a static IP address 192.168.3.30 and is connected from its WLAN port to the LAN port of the “Speedport 3”. The GL-AXT1800 is configured as a VPN client and so far everything works.
how do I now have to configure GL-AXT1800 router so that I can print to or reach a printer (IP of the printer 192.168.3.80) in the network 192.168.3.x. This printer should remain on the network and not be moved to the secure VPN network of the GL-AXT1800. someone can tell me here if this is possible and where I have to set this, so that I can print from the secure VPN network (GL-AXT1800) in the insecure “Speedport 3”, in which the printer is also located.
Thank you so much for your help
best regards
Andreas
Try setting up VPN Policy so that VPN is not used for IP 192.168.3.80 or 192.168.3.0/24.
