Does anyone know which version of AdGuard Home Version works with the GL-AXT1800 Slate AX, my GL-AX1800 Flint runs with no problems with AdGuardHome_linux_armv7 if the Slate is the same it would make life easier.
Thanks
Hi,Can work at V0.107.26.
Hi thanks for the reply but I was after the manual update package
Anyone updated AdGuard home on a Slate yet or is everyone on V0.107.26, I tried 7, 6 & 5 but don’t work (AdGuardHome_linux_armv)
Mabe i should rephrase the question, has anyone updated to AdGuard Home v0.107.29 if so which AdGuard version did you use.
