2 days ago I updated my GL-AXT1800 to the latest version (OpenWrt 23.05-SNAPSHOT / LuCI openwrt-23.05 branch git-25.222.75657-7ce34fe).
Upon reboot, when I access the Luci web interface, I get this error:
"An unknown error occurred. Please check your network environment or reboot the device."
I can log in correctly, but I still get the same error.
After a day or two, I can no longer access Luci and have to reboot the device from the OpenWrt interface.
Has anyone else had the same issue with the new firmware?
Thanks
Could you let us know the firmware version you upgraded from and to?
This error message usually appears when previous settings conflict with the current version.
Have you made any changes to the router settings through LuCI or SSH before?
We recommend resetting the router to factory settings and checking if that resolves the issue:
Repair network or reset - GL.iNet Router Docs 4
i don’t remember the old firmware, now i have OpenWrt 23.05-SNAPSHOT
In old firmware i’ve installed speedtest from cli, maibe thats the problem, now i will try to reset to factory default to check if it solve
Thanks
system
Closed
January 7, 2026, 4:02am
6
