GL-AXT1800 / v4.8.0 / Errors
I just updated one of my GL-AXT1800 with 4.8.0. The updated was with keeping current settings from 4.7.0. After upgrade and loging in, and clicking on "Clients" I keep seeing popup message at the top of the screen.
"Unknown error occurred. Please check the network environment or reboot the device."
After rebooting be router a few times, I keep seeing this error?
I see following in "Ngunx log". 192.168.8.10 is my machine IP I am connecting to from.
"192.168.8.1", referrer: "https://192.168.8.1/"
2025/06/02 11:28:39 [error] 9527#0: *821 lua entry thread aborted: runtime error: ./files/vpn-client.lua:1432: attempt to index local 'res' (a nil value)
stack traceback:
coroutine 0:
	./files/vpn-client.lua:1432: in function <./files/vpn-client.lua:1428>
	(tail call): ?
	/usr/share/gl-ngx/oui-rpc.lua:108: in function '?'
	/usr/share/gl-ngx/oui-rpc.lua:163: in function </usr/share/gl-ngx/oui-rpc.lua:1>, client: 192.168.8.10, server: , request: "POST /rpc HTTP/1.1", host: "192.168.8.1", referrer: "https://192.168.8.1/"
2025/06/02 11:28:44 [error] 9527#0: *826 lua entry thread aborted: runtime error: ./files/vpn-client.lua:1432: attempt to index local 'res' (a nil value)
stack traceback:
coroutine 0:
	(tail call): ?
2025/06/02 11:28:49 [error] 9527#0: *835 lua entry thread aborted: runtime error: ./files/vpn-client.lua:1432: attempt to index local 'res' (a nil value)
stack traceback:
coroutine 0:
	(tail call): ?
2025/06/02 11:28:54 [error] 9527#0: *842 lua entry thread aborted: runtime error: ./files/vpn-client.lua:1432: attempt to index local 'res' (a nil value)
stack traceback:
coroutine 0:
	(tail call): ?
In "System Log" I see following
Mon Jun  2 11:30:28 2025 daemon.err eco[17521]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:30 2025 daemon.err eco[17551]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:32 2025 daemon.err eco[17568]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:34 2025 daemon.err eco[17585]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:34 2025 daemon.err eco[2156]: (gl-ngx-session:271) call clients.get_list fail with http code: 302
Mon Jun  2 11:30:36 2025 daemon.err eco[17602]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:38 2025 daemon.err eco[17619]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:40 2025 daemon.err eco[17642]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:42 2025 daemon.err eco[17659]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:44 2025 daemon.err eco[17677]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:46 2025 daemon.err eco[17694]: call wifi.get_config fail with http code: 302
Mon Jun  2 11:30:48 2025 daemon.err eco[17711]: call wifi.get_config fail with http code: 302
Any ideas?
I suggest to either clear the browser cache (or use a private window) or do a factory reset.
I saw the reproduction steps you mentioned in the associated thread, and will conduct in-depth inspections:
But we have not reproduced this issue in the AXT1800 from v4.7.0 > v4.8.0 firmware, could you please PM me your AXT1800 backup configuration? we would like to reproduce this in my router and deep check.
I've got the same errors, every 2 seconds after updating my Beryl AX and Flint 2 to Beta 4.8
EDIT: seems to be because of the Force HTTPS option. And the error is extended for me for Clients tab too
Thank you very much for your feedback.
We have found the cause of this issue and will improve this issue in the next firmware version.
Update:
AXT1800 4.8.0 (beta9) or newer firmware is resolve this issue.
This worked for me, thank you!
