Hi. I’m having an issue with VPN connection on my GL-AXT1800.
I have setup OpenVPN to my router, allowed all WAN traffic on GL-AXT1800 and the same on the router I’m connecteing to but I’m getting no traffic at all. It’s all green and connected but I can’t access my local network at the destination.
On your router under the OpenVPN server (under the status tab), you have a button (looks like a switch button) that says "Allow Access Local Network " turn it on in order to see your local network. The button is on the top above the IP address,
The problem is now resolved. I was using my atx1800 connected to the 4G router. As soon I went a friends house I hooked up atx to normal cable router and it worked straight away.
There must be some limitations over 4G connection.
