Gl-axt800 0x80070035 error
I have axt800 and ac-88u asus the asus always good and easy for sharing the storage but I have always peoblem with axt800 gives this error on same the pc
whats wrong ?
ty I know how to config but still i have the same problem
dlna is working but cant get access to storage
Screenshot 2023-08-12 145044
Can you run a test using “\\router ip” where router ip is the IP address of the GL-AXT1800?
If this is successful, then the Netbios name may not be correct, or nmbd is not running. DLNA names are separate.
