I’m using a GL 1300 (FW 3.104) with OpenVPN and PIA, it works great… unless my provider want to change my IP (usualy every couple of month) and then the VPN is not able to reconnect…
I need to go into the router, abort the connection process and then connect again and it works…
Any idea?
Thank you,
Alex
