GL-B1300 disconnecting issue
My B1300 keeps disconnecting multiple times during the day. It is plugged directly in the wall, I have done a factory reset and it has the latest updates. I am running Hide My Ass vpn. Via openvpn, I have tried both tcp and udp connections. Is there any fix for this?
Can you let me know if it’s the VPN disconnect or the WAN disconnect?
I believe its the WAN disconnecting
Are you able to get the system log?
I do not see a way to do that via the mobile app. Is there a way I am missing?
You cannot do it via mobile app.
Pls use a pc.
You can ssh to the router and use logread to get the log.
Of install luci and get the system log via the UI.
I found a system log and kernel log. Is this what I need and is there a clean way to export.
There is no clean way to export. Can you send to me via private message?
I have the log files. How do I private message?
send via email support@gl-inet.com
Whats the best VPN and configuration combination to use with my router? My current setup is fairly slow.
Just use wireguard, not openvpn should be fine.
