GL-B1300 - Fail Over only works when WAN unplugged
Hi Everyone,
Got a GL-B1300 which seems like a great product, got everything working except Failover WAN / 4G
If I unplug the WAN it will failover to 4G near-instant.
if the WAN goes down it will say WAN is offline, but won’t fail over to 4G unless I unplug the WAN Cable.
Can’t seem to find a way to fix this?
Thanks!
More info…
Works out if openvpn client is connected, fail over won’t work. guessing because openvpn is not connected or something, But if i unplug the WAN openvpn will re-connect near instant and fail over works as intended.
Guessing this is a bug? or a setting i can look in to changing?
any help would be great!
Recorded this on dev list. Thanks for reporting.
Still no firmware update. Problem still exists…
let me check with the dev team.
Can you try 3.104 from GL.iNet download center
We actually fixed this bug but I don’t know if this is in 3.104.
Note: ddns is broken in 3.104 and under fixing.
