I logged on to my router today and noticed that under VPN was a yellow dot.
I clicked the drop down and the OpenVPN had a yellow dot next to it, but my kill switch had a green dot.
Anyone had this and know why?
This means killswitch is turned on.
This means vpn is broken. Is there any log?
No logs, as I actually factory reset it.
I did however check the IP and it was showing the VPN provider.
If it was broken, wouldn’t that mean the kill switch should have stopped internet?
If vpn is broken, you will not have Internet.
Killswitch does it further. If you do not connect vpn at all (disabled, not broken), no Interent.
