GL-B1300 use of DynDNS via DDNS
Hi, I have tried to use DynDNS (I have modified /etc/config/ddns and had put in two new sections for DynDNS below Gl-ddns section and have activated DDNS Service (of course restarted the DDNS service) but DDNS Service is not updating my IPs at DynDNS… What I am doing wrong?
Thx
SOMCON
Can you show your ddns config file?
Did you get this working ?
If so can you show me how to do it ? I have the same issue.
Thanks
Ben
Yes, it is working now.
This is my entry in ddns
config service ‘zzz’
option interface ‘wan’
option check_interval ‘10’
option check_unit ‘minutes’
option force_interval ‘60’
option force_unit ‘minutes’
option ip_url ‘http://checkip.dyndns.com
option ip_source ‘web’
option password ‘xxxx’
option username ‘yyyy’
option domain ‘zzz.dyndns.org
option param_enc ‘zzz’
option lookup_host ‘zzz.dyndns.org
option update_url ‘http://[USERNAME]:[PASSWORD]@members.dyndns.org/nic/updatesystem=dyndns&hostname=zzz.dyndns.org&myip=[IP]’
option enabled ‘1’
option service_name ‘dyn.com
