Out of the blue, my two Velica Mesh Router Stopped working.
I checked and there wasn’t any auto-upgrade but neither of them will connect to my network Gateway (Cox) which they did previously nor will they obtain an IP, DHCP, or Static settings.
Next, they somehow disconnected from the mesh network and will not reconnect with each other now either. I’m literally spent days and house pressing the “try again” button on the app, tried all distances and settings I’ve read in the blogs, nothing seems to work for either problem.
Hoping you have some magic instructions. Below is the log-in case that helps.
____ SYSTEM LOG
ue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.784533] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.791904] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.798458] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.805261] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.812276] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.819271] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.826527] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.833955] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.841421] Add VHT80 channel: 5210
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.844753] Add VHT80 channel: 5290
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.848263] Add VHT80 channel: 5530
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.851699] Add VHT80 channel: 5610
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.855170] Add VHT80 channel: 5690
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.858680] Add VHT80 channel: 5775
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.862145] Skipping VHT80 channel 5825
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.865939] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x200000) flags 0x4000100
Tue Apr 6 03:13:57 2021 kern.info kernel: [ 1971.873695] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x400000) flags 0x8000100
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.883074] freq=58
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.884279] freq=106
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.886590] freq=122
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.888798] freq=138
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.912360] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg00000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000, cfgvalid[2] 10000
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.927065]
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.927065] Already Disabled
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.949911] set TXBF_SND_PERIOD: value 100 wmi_status 0
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.980975] Disconnect_timeout value entered:10
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1971.989697] reconfiguration_timeout value entered:60
Tue Apr 6 03:13:57 2021 kern.warn kernel: [ 1972.029394] Switching to Tx Mode-1 Threshold 280
Tue Apr 6 03:13:58 2021 kern.info kernel: [ 1973.426572] br-lan: port 3(ath1) entered forwarding state
Tue Apr 6 03:13:59 2021 daemon.err gl_mqtt_service[8624]:
Tue Apr 6 03:13:59 2021 daemon.err gl_mqtt_service[8624]: utils_NLB failed!
Tue Apr 6 03:14:02 2021 user.notice ddns-scripts[14423]: glddns: PID ‘14423’ started at 2021-04-06 03:14
Tue Apr 6 03:14:02 2021 daemon.err gl_mqtt_service[8624]: url =
Tue Apr 6 03:14:02 2021 daemon.err gl_mqtt_service[8624]: utils_NLB failed!
Tue Apr 6 03:14:02 2021 user.err ddns-scripts[14423]: glddns: BusyBox nslookup error: ‘1’
Tue Apr 6 03:14:03 2021 user.err ddns-scripts[14423]: glddns: cURL Error: ‘6’
Tue Apr 6 03:14:03 2021 user.warn ddns-scripts[14423]: glddns: Transfer failed - retry 1/0 in 60 seconds
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.529888] send_vdev_down_cmd_non_tlv for vap 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.533675] ACS failed to derive the channel. So,selecting channel with least BSS
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.541064] random channel is 40
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.544347] ******** ACS report ********
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.548329] Channel | BSS | minrssi | maxrssi | NF | Ch load | spect load | sec_chan
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.556312] ---------------------------------------------------------------------
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.563785] 5180( 36) 11 8 80 -104 6 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.571772] 5200( 40) 1 55 55 -104 3 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.579780] 5220( 44) 5 9 10 -104 4 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.587749] 5240( 48) 6 52 63 -104 29 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.595733] 5260( 52) 0 0 0 -103 1 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.603719] 5280( 56) 0 0 0 -103 1 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.611707] 5300( 60) 0 0 0 -104 1 0 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.619691] 5320( 64) 1 9 9 -105 1 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.627676] 5500(100) 0 0 0 -105 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.635692] 5520(104) 0 0 0 -106 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.643674] 5540(108) 0 0 0 -106 1 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.651662] 5560(112) 0 0 0 -106 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.659654] 5580(116) 0 0 0 -107 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.667636] 5600(120) 0 0 0 -107 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.675619] 5620(124) 0 0 0 -107 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.683604] 5640(128) 0 0 0 -108 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.691600] 5660(132) 0 0 0 -108 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.699581] 5680(136) 0 0 0 -108 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.707561] 5700(140) 0 0 0 -108 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.715548] 5745(149) 0 0 0 -109 1 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.723535] 5765(153) 0 0 0 -109 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.731523] 5785(157) 0 0 0 -109 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.739503] 5805(161) 0 0 0 -110 1 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.747513] 5825(165) 0 0 0 -109 0 0 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.755655] OL vap_start +
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.758175] VDEV START
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.760537] OL vap_start -
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.763242] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.944488] ol_vdev_start_resp_ev for vap 0 (de9e6000)
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.948658] send_wmm_update_cmd_non_tlv:
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.952725] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.959636] send_vdev_up_cmd_non_tlv for vap 0
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.964013] Beacon mode set to staggered. Cannot enable FD
Tue Apr 6 03:14:04 2021 kern.warn kernel: [ 1978.969490] __ieee80211_smart_ant_init: Smart Antenna is not supported
Tue Apr 6 03:14:05 2021 daemon.err gl_mqtt_service[8624]: url
Tue Apr 6 03:14:05 2021 daemon.err gl_mqtt_service[8624]: utils_NLB failed!
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.115547] ME Pool succesfully initialized vaddr - d5360000 paddr - 0
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.115547] num_elems = 1424 buf_size - 64 pool_size = 102528
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.126822] Enable MCAST_TO_UCAST
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.135063] ME Pool succesfully initialized vaddr - d8b20000 paddr - 0
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.135063] num_elems = 1424 buf_size - 64 pool_size = 102528
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.146374] Enable MCAST_TO_UCAST
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.395136] STOPPED EVENT for vap 0 (dba32000)
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.398640] send_vdev_down_cmd_non_tlv for vap 0
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.416724] OL vap_start +
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.418423] VDEV START
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.420762] OL vap_start -
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.420953] ol_vdev_start_resp_ev for vap 0 (dba32000)
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.421107] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.421126] send_vdev_up_cmd_non_tlv for vap 0
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.421149] Beacon mode set to staggered. Cannot enable FD
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.421155] __ieee80211_smart_ant_init: Smart Antenna is not supported
Tue Apr 6 03:14:06 2021 kern.warn kernel: [ 1981.452296] ol_ath_vap_set_param: Now supported MGMT RATE is 1000(kbps) and rate code: 0x43
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.487001] STOPPED EVENT for vap 0 (dba32000)
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.490500] send_vdev_down_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 daemon.notice netifd: Network device ‘ath0’ link is down
Tue Apr 6 03:14:07 2021 kern.info kernel: [ 1981.517946] br-lan: port 2(ath0) entered disabled state
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.632836] send_vdev_delete_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.636784] ol_ath_vap_delete: wmi_unified_vdev_delete_send done ID = 0 vap (d89d8000) VAP Addr = 94:83:c4:0d:3c:17:
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.647244] ieee80211_mbo_vdetach: MBO terminated
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.651925] ieee80211_oce_vdetach: OCE terminated
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.656773] Suspending Target scn=db980500
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.660726] waiting for target paused event from target
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.666041] ol_ath_thermal_mitigation_detach: ++
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.670715] ol_ath_thermal_mitigation_detach: –
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.675246] ol_if_dfs_clist_update: called, cmd=1, nollist= (null), nentries=0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.685673] ce_h2t_tx_ce_cleanup 1039 Fastpath mode ON, Cleaning up HTT Tx CEDisabling Mcastenhance. This may take some time…
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.723792] Reset complete for wifi core id : 0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.727361] hif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.732949] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Tue Apr 6 03:14:07 2021 kern.info kernel: [ 1981.746013] br-lan: port 2(ath0) entered disabled state
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.894360] STOPPED EVENT for vap 0 (de9e6000)
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.897862] send_vdev_down_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.916845] OL vap_start +
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.918580] VDEV START
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.920899] OL vap_start -
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.923586] ol_vdev_start_resp_ev for vap 0 (de9e6000)
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.923751] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 1
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.923770] send_vdev_up_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.923795] Beacon mode set to staggered. Cannot enable FD
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.923802] __ieee80211_smart_ant_init: Smart Antenna is not supported
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.952481] ol_ath_vap_set_param: Now supported MGMT RATE is 6000(kbps) and rate code: 0x3
Tue Apr 6 03:14:07 2021 daemon.notice netifd: Network device ‘ath1’ link is down
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1981.996980] STOPPED EVENT for vap 0 (de9e6000)
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.000629] send_vdev_down_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 kern.info kernel: [ 1982.007034] br-lan: port 3(ath1) entered disabled state
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.142699] send_vdev_delete_cmd_non_tlv for vap 0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.146503] ol_ath_vap_delete: wmi_unified_vdev_delete_send done ID = 0 vap (d9f58000) VAP Addr = 94:83:c4:0d:3c:18:
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.157075] ieee80211_mbo_vdetach: MBO terminated
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.161664] ieee80211_oce_vdetach: OCE terminated
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.166425] Suspending Target scn=d9840500
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.170560] waiting for target paused event from target
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.175845] ol_ath_thermal_mitigation_detach: ++
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.180490] ol_ath_thermal_mitigation_detach: –
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.185045] ol_if_dfs_clist_update: called, cmd=1, nollist= (null), nentries=0
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.197171] ce_h2t_tx_ce_cleanup 1039 Fastpath mode ON, Cleaning up HTT Tx CEDisabling Mcastenhance. This may take some time…
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.236534] Reset complete for wifi core id : 1
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.240203] hif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.245724] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Tue Apr 6 03:14:07 2021 kern.warn kernel: [ 1982.253898] channel is not 2.4G return faile
Tue Apr 6 03:14:07 2021 kern.info kernel: [ 1982.262953] br-lan: port 3(ath1) entered disabled state
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.585883] [ol_ath_iw_setcountry][1832] *p=55, *(p+1)=53
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.590393] *********** IPQ4019 *************Wifi0 CPU frequency 250000000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.617602] hif_target_sync_ahb: Got FW signal, retries = 1hif_ahb_enable_bus: X - hif_type = 0xd, target_type = 0xbhif_config_ce: ce_init donehif_config_ce: X, ret = 0hif_set_hia: Ehif_pci_bus_configure: hif_set_hia donehif_configure_irq: Ehif_enable: X OKhif_napi_create: NAPI structures initializedhif_napi_create: NAPI id 6 created for pipe 5qca_napi_create: napi instance 32 created on pipe 4
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.655762] hif_napi_event: received evnt: CONF cmd; v = 1 (state=0x1)hif_napi_event: setting configuration to ON
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.666055] ol_target_init() BMI inited.
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.670095] ol_target_init() BMI Get Target Info.
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.674695] Chip id: 0xb, chip version: 0x1000000
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.679330]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.679330] CE WAR Disabled
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.683756] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.689217] ol_target_init() configure Target .
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.693601]
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.693601] Target Version is 1000000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.698756]
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.698756] Flash Download Address c0000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.704368] ol_transfer_bin_file: flash data file defined
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.709778] ol_transfer_bin_file[3773] Get Caldata for wifi0.
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.715537] qdf_fs_read[59], Open File /tmp/wifi0.caldata SUCCESS!!file system magic:16914836super blocksize:4096inode 3116file size:12064qc98xx_verify_checksum: flash checksum passed: 0x8196
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.732495] ol_transfer_bin_file 3834: Download Flash data len 12064
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.739205] Board extended Data download address: 0x0
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.763417]
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.763417] Board data initialized
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.767459] ol_ath_download_firmware: Download OTP, flash download ADDRESS 0xc0000
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.774985]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.774985] Selecting OTP binary for CHIP Version -1063631476
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.782483] ol_transfer_bin_file 3654: downloading file 0, Download data len 4680
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.806208]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.806208] First OTP send param 8000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.815199] ol_ath_download_firmware :First OTP download and Execute is good address:0x5000 return param 4660
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.824156] ol_ath_download_firmware:##Board Id 20 , CHIP Id 0
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.830058] ol_ath_download_firmware: BOARDDATA DOWNLOAD TO address 0xc0000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.837447]
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.837447] wifi0: Selecting board data file name boardData_1_0_IPQ4019_DK04_2G.bin
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.846062] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_1_0_IPQ4019_DK04_2G.bin
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.858422] ol_transfer_bin_file 3654: downloading file 3, Download data len 12064
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.866081] Board extended Data download address: 0x0
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.890524] ol_ath_download_firmware: Using 0x1234 for the remainder of init
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.896565]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.896565] Selecting OTP binary for CHIP Version -1063631476
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.904069] ol_transfer_bin_file 3654: downloading file 0, Download data len 4680
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.927805]
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.927805] [Flash] : Ignore Module param
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.932346]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.932346] Second otp download Param 10000
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.948513] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.955740]
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.955740] Mission mode: Firmware CHIP Version -1063631476
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.963321] ol_swap_wlan_memory_expansion: length:165455 size_left:165475 dma_size_left:262144 fw_temp:e4a81004 fw_entry_size:165479
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.974848] ol_swap_wlan_memory_expansion: dma_virt_addr :e103a000 fw_temp: e4a81008 length: 165455
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1982.984100] Swap: bytes_left to copy: fw:16; dma_page:96689
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1982.989384] ol_swap_wlan_memory_expansion: length:0 size_left:12 dma_size_left:96689 fw_temp:e4aa965b fw_entry_size:165479
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1983.000390] Swap: wrong length read:0
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1983.004010] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 165455 Target address 417b70
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1983.013051] scn=db980500 target_write_addr=417b70 seg_info=dedacb10
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1983.019328] ol_transfer_swap_struct:Code swap structure successfully downloaded for bin type =2
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1983.028075] bin_filename=IPQ4019/hw.1/athwlan.bin swap_filename=/lib/firmware/IPQ4019/hw.1/athwlan.codeswap.bin
Tue Apr 6 03:14:08 2021 kern.warn kernel: [ 1983.038335] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
Tue Apr 6 03:14:08 2021 kern.info kernel: [ 1983.046853] ol_transfer_bin_file 3654: downloading file 1, Download data len 372480
Tue Apr 6 03:14:09 2021 daemon.err gl_mqtt_service[8624]: url
Tue Apr 6 03:14:09 2021 daemon.err gl_mqtt_service[8624]: utils_NLB failed!
Tue Apr 6 03:14:09 2021 kern.info kernel: [ 1984.308112] ol_target_init() Download FW done.
Tue Apr 6 03:14:09 2021 kern.warn kernel: [ 1984.311953]
Tue Apr 6 03:14:09 2021 kern.warn kernel: [ 1984.311953] ol_ath_copy_tgt_iram() iram read paddr: 0x980000 host paddr 0x87500000 Radio id 0
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.487124] +htc_create … HIF :da078000-htc_create: (0xdd378800)
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.492108] htc_wmi_init() HT Create . dd378800
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.496880] htc_wmi_init 7754 host_enable 0 nss_nwifi_offload 0
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.502699] ol_ath_set_default_tgt_config : AC Minfree buffer allocation through module param (umac.ko)
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.512314] OL_ACBKMinfree : 0
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.515196] OL_ACBEMinfree : 0
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.518426] OL_ACVIMinfree : 0
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.521444] OL_ACVOMinfree : 0
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.524571] hif_enable_fastpath, Enabling fastpath mode
Tue Apr 6 03:14:10 2021 kern.alert kernel: [ 1984.529656] +HWT
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.531600] hif_completion_thread_startup: pipe_num:0 pipe_info:0xda07cb78hif_completion_thread_startup: pipe_num:3 pipe_info:0xda07cc50hif_completion_thread_startup: pipe_num:4 pipe_info:0xda07cc98
Tue Apr 6 03:14:10 2021 kern.alert kernel: [ 1984.552580] -HWT
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.553561] wmi_unified_register_event_handler : event handler already registered 0x8002
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.561743] Startup Mode-0 set
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.564665] pdev attach (null) -1
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.568256]
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.568256] <=== cfg max peer id 1056 ====>
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.574291] htt_peer_map_timer_init Enter pdev d6a90000 hrtimer d6a94948
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.580601]
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.580601] htt_alloc_peer_map_mem : Alloc Success : host q vaddr de204000 paddr 9e204000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.590344]
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.590344] htt_alloc_peer_map_mem : Flush Interval Configured to 256 pkts
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.600849] ol_txrx_pdev_attach: 2500 tx desc’s allocated ; range starts from d8b20000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.609892] Firmware_Build_Number:7
Tue Apr 6 03:14:10 2021 kern.alert kernel: [ 1984.612456] host/RAM_fw Build Ver Mismatch: H:0x32, F:0x7 !
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.618282] FW wireless modes: 0x680c
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.621740] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht_cap_info:0x339959b2 vht_supp_mcs:0x0000fffa
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.631641] btcoex_support 0, wlan_prio_gpio 0, coex_gpio_pin 0 0 0
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.638037] wmi_service_coex_gpio 1, wmi_service_4_wire_coex_support 1, coex_version 0
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.645786]
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.645786] Sending Ext resource cfg: HOST PLATFORM as 0
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.645786] fw_feature_bitmap as 50 to TGT
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.656873] ol_ath_service_ready_event: tt_support: 1
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.661671] ol_ath_service_ready_event: periodic_chan_stats: 1
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.667621] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.673824] Peer Caching Enabled ; num_peers = 530, num_active_peers = 52 num_tids = 104, num_vdevs = 17
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.683481] EXT NSS Supported
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.686251] idx 1 req 2 num_units 1 num_unit_info 12 unit size 256 actual units 53
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.694000] ol_ath_alloc_host_mem_chunk req_id 2 idx 0 num_units 53 unit_len 256,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.701449] idx 2 req 3 num_units 1 num_unit_info 12 unit size 1024 actual units 53
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.709254] ol_ath_alloc_host_mem_chunk req_id 3 idx 1 num_units 53 unit_len 1024,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.716809] idx 3 req 4 num_units 1 num_unit_info 12 unit size 4096 actual units 53
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.724603] ol_ath_alloc_host_mem_chunk req_id 4 idx 2 num_units 53 unit_len 4096,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.732170] idx 0 req 1 num_units 0 num_unit_info 2 unit size 744 actual units 531
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.739896] ol_ath_alloc_host_mem_chunk req_id 1 idx 3 num_units 531 unit_len 744,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.747445] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual units 35
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.755246] ol_ath_alloc_host_mem_chunk req_id 6 idx 4 num_units 35 unit_len 3072,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.762812] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual units 1
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.770449] ol_ath_alloc_host_mem_chunk req_id 7 idx 5 num_units 1 unit_len 6144,
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.777916] idx 6 req 5 num_units 0 num_unit_info 2 unit size 2028 actual units 531
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.785715] ol_ath_alloc_host_mem_chunk req_id 5 idx 6 num_units 531 unit_len 2028,
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.793366] Support not added yet for Service 91
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.797963] Support not added yet for Service 92
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.802548] No EXT_MSG send INIT now
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.806117] chunk 0 len 13568 requested , ptr 0x9ba64000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.811513] chunk 1 len 54272 requested , ptr 0x99d00000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.816889] chunk 2 len 217088 requested , ptr 0x99d40000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.822344] chunk 3 len 395064 requested , ptr 0x99d80000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.827823] chunk 4 len 107520 requested , ptr 0x99d20000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.833280] chunk 5 len 6144 requested , ptr 0x9bac4000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.838590] chunk 6 len 1076868 requested , ptr 0x99e00000
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.844181] ol_ath_service_ready_event[4251] WAPI MBSSID 2
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.849864] smart_log_init: Smart logging Enabled buf=d4900000 (size=65536)
Tue Apr 6 03:14:10 2021 kern.warn kernel: [ 1984.885974] Version = 16777216 3 status = 0
Tue Apr 6 03:14:10 2021 kern.info kernel: [ 1984.889308] ol_ath_connect_htc() WMI is ready
