GL-B3000 (Marble) - Wi-Fi extender
GL-B3000 has a repeater feature, but in my case I would like to extend the Wi-Fi signal coverage conecting GL-B3000 to the main router by ethernet and then setting the Wi-Fi to the same SSID of the main router, so the devices can see an stronger wi-fi signal.
Is there any way do to this?
Yes. You need to enable access point mode from the gui.
Thanks. I was looking for this feature on another menu.
Maybe could be better if they add this feature also here on the "Status diagram"
