GL-BE14000 (Flint 4) – Full Cone NAT not working as expected and Manual DNS (Quad9) issues on firmware 4.11.0 Beta 6
Hello GL.iNet Team,
I would like to report two issues with my GL.iNet Flint 4 (GL-BE14000), currently running firmware 4.11.0 Beta 6.
I have investigated both issues using SSH, OpenWrt configuration checks, nftables diagnostics, DNS tests, and packet captures.
I would appreciate feedback from the GL.iNet developers regarding these behaviors.
1. System information
  • Router: GL.iNet Flint 4 (GL-BE14000)
  • Firmware: 4.11.0 Beta 6
  • OpenWrt base: 25.12-SNAPSHOT
  • Kernel: 6.12.94 (previously recorded)
  • ISP: Deutsche Telekom, Germany
  • Connection: VDSL 250 Mbps
  • Modem: DrayTek Vigor167 in bridge mode
  • WAN connection: PPPoE, established directly by the Flint 4
  • WAN interface: pppoe-wan
  • LAN subnet: 192.168.8.0/24
  • Hardware acceleration: Disabled
  • IPv4 NAT: Enabled
  • IPv6: Enabled
  • DNS provider: Quad9
  • Tailscale: Installed and running
The DrayTek Vigor167 operates only as a bridge modem. The Flint 4 handles PPPoE authentication, routing, firewalling, and NAT.
2. Issue #1 – Full Cone NAT does not behave as expected
Expected behavior
When Full Cone NAT is enabled in the GL.iNet web interface, the router should provide the documented Full Cone NAT behavior for applicable IPv4 UDP connections.
Actual behavior
Full Cone NAT is enabled in the GL.iNet interface, and the corresponding configuration value is set to:
enable=1
However, external NAT tests continue to report:
Port Restricted Cone NAT
This is unexpected because Full Cone NAT is explicitly enabled.
Diagnostics performed
I inspected the nftables NAT rules and verified that the firewall contains Full Cone-related rules.
I also tested a custom nftables configuration to investigate the behavior.
Example rule from my diagnostic setup:
oifname "pppoe-wan" ip saddr {
  10.0.0.0/8,
  172.16.0.0/12,
  192.168.0.0/16
counter return comment "FULLCONE_ALL"
The packet counters increased, confirming that traffic reached the rule.
However, this did not establish that Full Cone NAT was functioning correctly.
The custom rule was part of additional troubleshooting and should not be confused with a verified fix or the stock GL.iNet implementation.
Questions for GL.iNet developers
  1. Is Full Cone NAT fully supported and functional on the GL-BE14000 with firmware 4.11.0 Beta 6?
  2. Is there a known issue involving Full Cone NAT and PPPoE connections?
  3. Does the current implementation require specific nftables modules, firewall rules, or other settings?
  4. Is Full Cone NAT affected by hardware acceleration being disabled?
  5. Which official test procedure does GL.iNet recommend to verify endpoint-independent mapping and filtering?
  6. Is a fix planned for an upcoming firmware release?
3. Issue #2 – Manual DNS / Quad9 behavior
I am also investigating an issue with manual DNS configuration using Quad9.
Expected behavior
When Quad9 is configured as the custom DNS provider, DNS queries covered by the selected DNS policy should use the configured Quad9 servers.
In particular, I would expect the router to respect the selected Manual DNS settings without unexpectedly falling back to ISP-provided DNS servers.
DNS environment
My router uses dnsmasq together with a local DNS proxy.
Relevant settings observed during troubleshooting:
dnsmasq:
noresolv=1
server=127.0.0.1#5453
Local DNS proxy:
127.0.0.1:5453
TCP/UDP
Quad9 DNS-over-TLS was confirmed using the provider's diagnostic TXT record:
proto.on.quad9.net
The response indicated:
dot
This suggests that Quad9 DNS-over-TLS is operational for the tested query.
However, this does not prove that every DNS request from every LAN client is routed through Quad9.
Additional observations
I captured DNS traffic on the LAN bridge using:
tcpdump -ni br-lan -nn -q \
'udp port 53 or tcp port 53'
DNS activity from individual LAN clients was observed.
One client under investigation used:
192.168.8.214
I also checked the ARP/neighbour table and DHCP leases.
The results suggest that further investigation is needed to determine how DNS requests from different clients are handled and whether Manual DNS policies are consistently applied.
  1. Are there any known issues with Manual DNS or Quad9 on firmware 4.11.0 Beta 6?
  2. How does firmware 4.11 prioritize manually configured DNS servers versus PPPoE/ISP-provided DNS servers?
  3. Can IPv6 DNS configuration or Router Advertisements cause clients to use different DNS resolvers?
  4. Does the router's DNS proxy consistently apply Manual DNS settings to both IPv4 and IPv6 queries?
  5. How should DNS behavior be verified when Tailscale is installed but Tailscale DNS is disabled?
  6. Can GL.iNet provide an official diagnostic procedure to verify the effective upstream DNS server and identify possible DNS leaks?
4. Requested assistance
Could the GL.iNet development team please investigate these two issues on the GL-BE14000?
I would particularly appreciate:
  • Confirmation of the expected Full Cone NAT implementation on firmware 4.11.0 Beta 6.
  • Information about known PPPoE-related NAT limitations.
  • Clarification of Manual DNS priority and IPv6 DNS behavior.
  • Recommended diagnostic commands that do not change the current configuration.
  • Information about whether fixes are already included in a newer beta or planned firmware release.
I can provide additional SSH command output, sanitized nftables rules, DNS configuration details, and packet captures if required.
Thank you for your support and continued development of the Flint 4.
Best regards,
Adnan
Hi, thank you for the detailed report.
We have performed preliminary tests on the Flint 4 running firmware 4.11.0 Beta 6 and confirmed that the Full Cone NAT configuration and firewall rules were applied successfully.
The manual Quad9 DNS settings also took effect, and DNS-over-TLS queries worked correctly, with no unexpected fallback to ISP DNS observed in our test queries.
We would like to investigate further using your device’s configuration and network environment. Could you please follow this guide to enable remote access and share your device with GL.iNet Support through GoodCloud?
Atfer sharing, please send us the device’s MAC address and temporary admin password via private message.
Thank you for your cooperation and patience.
