I recently purchased a GL-BE3600 and tried using it with a Huawei E3372h-607 modem stick, but no matter what I do, it only shows "No modem device found." How should I set it up? --- The modem stick and SIM card should be fine; I tested them on a PC, and the internet works well.
Thank you
P.S. I have almost no IT knowledge.
I think the router can identify the connected e3372h-607 as a tethering device.
Does the BE3600 use the factory power supply?
Can it be switched to Hi-Link mode?
Does it support WiFi? If yes, you can connect GL router to its WiFi through repeater.
[quote="bruce, post:2, topic:61179"]
- Does the BE3600 use the factory power supply?
No, I will try today - Can it be switched to Hi-Link mode?
Yes - Does it support WiFi? If yes, you can connect GL
I'm not sure I google for information they told me it support wifi while the store where I bought it said it doesn't support Wi-Fi.
Thanks ![]()
Hello Thanks again for your advice, finally I can connect to the internet via tethering. ![]()
