I connected a GL Inet router with wireguard server ON to a 4g router and enabled port forwarding on it. My 4g router has both v4 and v6 addresses.
I want to use v6 address to build wireguard tunnel, but I might be doing some wrong wireguard configuration I gather. Perhaps wrong DNS or some other setting.
I am trying to connect with wireguard Android app. My phone has both v6 and v4.
Here are my logs and configuration:
[Question 1]
What can I do to connect the app to WG server? Looks like the IPV4 is behind a CGNAT,. but I was able to reach to an ipv6 server hosted on router okay. My DDNS also resolves okay. Is there a way to force app to use V6 to connect?
Do I need to change the IPV6 mode?
[Question 2]
Do I need to change the DNS?
[Question 3]
"If you use functions of both VPN and IPv6 at the same time, it's likely to cause IPv6 data leakage."
What does this mean? How can I prevent this data loss?
