GL-E5800 (Mudi 7) — cellular session issues, raw log captures
Device: GL-E5800, firmware 4.8.5, Quectel RG650V-EU
QRM650VEU00ADR02A04G8G_OCPU_RGH_01.005.01.005
Package: gl-sdk4-cellular git-2026.156.24582-f1aa5a0-1
(gl-sdk4-cellular_git-V4.9_disconnect_test.ipk installed)
SIM: Free Mobile FR (208 15), roaming Austria, +COPS: 0,0,"3 AT",7 (232 05)
APN free. Current config: ip_type=IP (IPv4-only), default MTU, no band mask.
All excerpts are verbatim from /etc/sys_log.
Issue 1 — Network periodically deactivates the data session (ESM cause 36)
What we face: the internet connection drops every ~10–30 minutes (bursts down
to 2–4 minutes apart), whether idle or mid-download. Each event assigns a new WAN
IP, so all TCP/VPN sessions die. VoLTE/IMS stays up. With the test IPK the router
recovers in ~40–55 s; the network refuses the first re-activation attempts for
~35 s of that.
Observations:
Deactivation with re-activation retries (session ~20 min old, light traffic):
Wed Aug 5 23:32:26 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=0 CallendCode=0) cb_msg.wwan_status:0x0
Wed Aug 5 23:32:26 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=6 CallendCode=36) cb_msg.wwan_status:0x6
Wed Aug 5 23:32:42 2026 user.info Diag_Lib[12932]: (cm.c:8743) Executing dial disconnection, initiated by PREPARE_DIAL (bus: cpu, slot: 1 interface:modem_cpu update_status:0 dial_status_flag:0)
Wed Aug 5 23:32:43 2026 user.info Diag_Lib[12932]: (cm.c:8619) Executing dial connect, initiated by INTERFACE OFFLINE (bus: cpu, slot: 1 interface: modem_cpu)
Wed Aug 5 23:32:52 2026 user.info Diag_Lib[12932]: (network.c:2900) get_network_info failed, bus=cpu slot=1
Wed Aug 5 23:33:00 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 1/3)
Wed Aug 5 23:33:12 2026 user.info Diag_Lib[12932]: (network.c:2900) get_network_info failed, bus=cpu slot=1
Wed Aug 5 23:33:17 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 2/3)
Wed Aug 5 23:33:19 2026 user.info Diag_Lib[12932]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.158.231.97 ctx_ipv6:
AT+CEER queried after this event:
+CEER: Network failure
Deactivation during an active multi-GB download (session age 12 min):
Wed Aug 5 23:12:06 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=0 CallendCode=0) cb_msg.wwan_status:0x0
Wed Aug 5 23:12:06 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=6 CallendCode=36) cb_msg.wwan_status:0x6
Wed Aug 5 23:12:06 2026 daemon.info gl-repeater[10581]: (repeater.lua:2177) interface modem_cpu down
Wed Aug 5 23:12:06 2026 daemon.info gl-repeater[10581]: (repeater.lua:1849) switch in 3 seconds...
Wed Aug 5 23:12:22 2026 user.info Diag_Lib[12932]: (cm.c:8743) Executing dial disconnection, initiated by PREPARE_DIAL (bus: cpu, slot: 1 interface:modem_cpu update_status:0 dial_status_flag:0)
Wed Aug 5 23:12:22 2026 user.info Diag_Lib[5258]: (cm.c:5753) disconnect by qmap start
Wed Aug 5 23:12:22 2026 user.info Diag_Lib[5258]: (cm.c:5787) disconnected by qmap end
Burst — three events in five minutes:
Thu Aug 6 00:00:38 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=6 CallendCode=36) cb_msg.wwan_status:0x6
Thu Aug 6 00:00:55 2026 user.info Diag_Lib[12932]: (cm.c:8619) Executing dial connect, initiated by INTERFACE OFFLINE (bus: cpu, slot: 1 interface: modem_cpu)
Thu Aug 6 00:01:12 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 1/3)
Thu Aug 6 00:01:29 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 2/3)
Thu Aug 6 00:01:31 2026 user.info Diag_Lib[12932]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.29.41.121 ctx_ipv6:
Thu Aug 6 00:03:26 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=3 CallendCode=1026) cb_msg.wwan_status:0x6
Thu Aug 6 00:03:44 2026 user.info Diag_Lib[12932]: (cm.c:8619) Executing dial connect, initiated by INTERFACE OFFLINE (bus: cpu, slot: 1 interface: modem_cpu)
Thu Aug 6 00:03:53 2026 user.info Diag_Lib[12932]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.158.231.208 ctx_ipv6:
Thu Aug 6 00:04:37 2026 user.info Diag_Lib[12932]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=6 CallendCode=36) cb_msg.wwan_status:0x6
Thu Aug 6 00:04:54 2026 user.info Diag_Lib[12932]: (cm.c:8619) Executing dial connect, initiated by INTERFACE OFFLINE (bus: cpu, slot: 1 interface: modem_cpu)
Thu Aug 6 00:05:19 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 1/3)
Thu Aug 6 00:05:37 2026 user.info Diag_Lib[12932]: (cm.c:3590) Failed to activate pdp state to module (retry 2/3)
Thu Aug 6 00:05:39 2026 user.info Diag_Lib[12932]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.29.106.226 ctx_ipv6:
PDN state across events (AT queries, before → after — same values except cid 1):
+CGPADDR: 1,"10.61.215.211" <- changes at every event
+CGPADDR: 2,"253.222.0.0.1.31.108.242.0.0.0.0.181.22.201.105" <- unchanged across events
+CGPADDR: 3,"0.0.0.0","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
+CEREG: 0,5 <- unchanged across events
+CGCONTRDP: 1,5,"free","10.95.154.208",,"212.27.40.190","212.27.40.191"
+CGACT: 1,1
+CGACT: 2,1
+CGACT: 3,0
Radio at event time (15 s sampler):
+QENG: "servingcell","NOCONN","LTE","FDD",232,05,1DDDD64,418,500,1,5,5,27AE,-84,-13,-51,16,6,60,-
+QCAINFO: "PCC",500,100,"LTE BAND 1",5,418,-84,-10,-54,12
+QCAINFO: "SCC",1525,75,"LTE BAND 3",1,388,-93,-7,-76,14,1,75,19525
+QTEMP: "mdmss-0","37" (all sensors 27–40 °C at all events)
CallendType=6 CallendCode=36 lines per day (v4/v6 pairs counted twice):
Jun 3: 5 Jul 28: 24 Jul 29: 10 Jul 30: 35 Jul 31: 24
Aug 1: 23 Aug 2: 22 Aug 3: 75 Aug 4: 11 Aug 5: 64
Jun 3 events occurred on home network 208 15 (France). Hourly distribution peaks
14:00–23:00 every day; near zero 01:00–09:00.
Issue 2 — IPV4V6 dial while roaming: IPv6 never granted, cm re-dials in a loop
What we face: with APN IP type IPV4V6, every dial while roaming succeeds
for IPv4 but gets no IPv6 context; the connection manager then tears the working
IPv4 session down and re-dials on an ~80 s cycle, escalating to forced radio
re-registration. Switching the APN to IPv4-only stops the loop entirely.
Observations:
Roaming — all sampled dual-stack dials return empty ctx_ipv6::
Wed Aug 5 17:46:40 2026 user.info Diag_Lib[14285]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.47.25.57 ctx_ipv6:
Wed Aug 5 17:57:33 2026 user.info Diag_Lib[14285]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.29.118.192 ctx_ipv6:
Wed Aug 5 18:14:06 2026 user.info Diag_Lib[14285]: (cm.c:8012) Dial success with APN: free ctx_ipv4:10.31.141.17 ctx_ipv6:
Home network (208 15, France, June 3) — the same dual-stack dial DID receive an
IPv6 context:
Wed Jun 3 00:01:26 2026 ... (cm.c:3827) Dial success with MCC:208 MNC:15 APN: free.re CID:1 IP_type :IPV4V6 ctx_ipv4:10.111.40.205 ctx_ipv6:42.13.228.135.23.127.60.164.0.0.0.0.55.179.245.21
Wed Jun 3 06:02:26 2026 ... (cm.c:3827) Dial success with MCC:208 MNC:15 APN: free CID:1 IP_type :IPV4V6 ctx_ipv4:10.63.95.106 ctx_ipv6:42.13.228.135.35.79.63.103.0.0.0.0.55.192.64.64
Post-dial failure codes in the roaming + IPV4V6 configuration (Aug 5 pre-reboot
counts: 27 × code 210, 32 × type 3/2000):
Tue Jul 28 12:18:24 2026 user.info Diag_Lib[12785]: (cm.c:4069) wwan handle:1 sub_id:0 (CallendType=2 CallendCode=210) cb_msg.wwan_status:0x8
Wed Jul 29 03:26:00 2026 user.info Diag_Lib[14431]: (cm.c:5493) wwan handle:1 sub_id:0 (CallendType=6 CallendCode=50) cb_msg.wwan_status:0x8
(ESM cause 50 = "PDN type IPv4 only allowed".) Escalation:
Wed Aug 5 21:30:51 2026 user.info Diag_Lib[14285]: (cm.c:7458) Start force re-register network(CFUN=4 -> CFUN=1)...
After switching to ip_type=IP + reboot at 21:51: code 210 count 27 → 0,
type 3/2000 count 32 → 1, forced CFUN re-registrations 2 → 0. The Issue 1
deactivations continued unchanged.
Issue 3 — Manual Cellular MTU (1360) kills the session under sustained transfer
What we face: with a manual MTU of 1360 set in the Cellular settings, every
sustained download died within 30–105 s. With MTU on default, multi-GB transfers
run with only the Issue 1 periodic deactivations.
Observations:
With network.modem_cpu.mtu='1360' — download tests run ON the router
(curl -o /dev/null, single stream, ipv4.download.thinkbroadband.com):
run 1: full rate, died t=73 s, 390,572,443 bytes (event 22:36:08)
run 2: full rate, died t=30 s, 101,402,419 bytes (event 22:40:38)
run 3: 500 KB/s cap, died t=105 s, 55,354,279 bytes (event 22:44:59)
A client game update through the router died at ~100 MB under the same config.
After removing the override (default MTU, reboot at ~23:00): the same game
update transferred ~3 GB; the only deactivations in that period were the Issue 1
periodic ones (23:12:06, 23:32:26), not correlated with transfer start. Reboots
alone (21:50, 22:19) had not changed the under-load behaviour.
Issue 4 — After rapid deactivation/redial churn, the modem stops responding
What we face: during a phase of rapid session deaths (Issue 3 config, client
download retrying), the router could not reconnect for 6 minutes and finally the
modem stopped answering; only a power cycle recovered it.
Observations:
After the 22:54:11 deactivation, seven dial attempts over six minutes produced
no Dial success and no call-end codes, then:
Wed Aug 5 22:59:58 2026 user.info Diag_Lib[12932]: (cm.c:3497) Failed to get cell info form module (retry 1/30) ret[-1]
Wed Aug 5 22:59:59 2026 user.info Diag_Lib[12932]: (cm.c:3497) Failed to get cell info form module (retry 2/30) ret[-1]
Device was power-cycled at ~23:00 to recover.
