GL-E750 4.3.6 is missing
Stable and beta firmware 4.3.6 is not showing anymore on the download page. Should I revert to the 3.217 version?
4.3.8 is really good, try it
I tried it and it is not “really good”…
SIM was not able to connect to the network after so many tries
During “gl-sdk4-ui-nasview” installation, the router SSID disappeared.
MCU is showing that everything is normal but the modem SSID was not visible after a few reboots.
reverted to 3.217 and everything is back to normal.
So, just keep using 3.217. My main router Flint even has 4.5 rn, I’m still using 3.x firmware.
