I suck at hardwre, software and English is not my native language. So I'm going to make mistakes in the way I express myself and pass on the information I need to solve my problem, and despite my best efforts, I'm going to have great difficulty understanding you most of the time.
Thank you for your patience.
Router: GL-E750
Firmware: 0319release3
Version: 4.0
Connection router->pc: ethernet and/or wifi
Here are the two messages sent to the seller without any response to date.
I can't connect to Tor!*
What can I see on the screen (from the computer connected to the router via ethernet) ?
Initilization tor configuration” and, on the right and in orange: ”internet.
connecting”. -
Very occasionally, on the left of the screen, the diote to the right of “Tor” appears for a second or two, but NEVER turns green.
I have :
- changed VPN server several times with no change (Tor doesn't connect)
- VPN works perfectly without Tor
- reset the firmware
- reset the router (press “reset”)
I've noticed some changes in the “menu_btnsettings” menu (menu_system): the drop-down list of options no longer proposes changing the IMEI but
- tor (On∕Off)
- menu_ovpnclient (On∕Off)
- menu_wgclient (On∕Off)
- btnsettings.no-func_babel ... which I don't understand!!!!
I have, of course; tried different configurations, with button up or down and, on screen “core_enable” or not in the Tor submenu.
What's going on and what can I do?
I'm still waiting for a solution to the malfunction reported in my previous e-mail.
I've just tried to connect to Tor, but to no avail. As for several days now, the process starts - initialization tor configuration / diote orange more than intermittent / connecting - but NOTHING more.
None, as in the first few days of using the router, progress message when creating the Tor circuit - 5% ... 38% ...
After a while, my computer's hard disk overheats (the fan kicks in), proof that it's working, but ... for nothing.
As you can imagine, I tried several times to reset the hardware and software, but to no avail. The first automatic software update went off without a hitch, but today I'm leaning more towards a software fault (new update confirmed by various small changes in the layout and management options of the button on the left of the router (Tor on/off)).
Best regards,
Still no progress today (25/06).
VPN+Tor
I let the connection attempt (to Tor) run for over half an hour, but ... nothing. The process seems to stall in the early stages.
VPN=Tor worked very well during the first two weeks of use, and I regularly changed both my Mac and IMEI addresses.
I really don't understand what could have caused this problem.
P.-S. There's been a Tor update lately (17/09) :
Full changelog
The full changelog since Tor Browser 13.5.3 is:
All Platforms
Updated NoScript to 11.4.37
**Updated OpenSSL** to 3.0.15
