The modem code glinet is not open source, you can get the state yourself via the AT instruction and send it to the mcu.
I see just wondering if GL can provide a static build of the e750-mcu
program with the closed source libraries that we can optionally install?
I still canāt figure out why the program is not updating the display after one time.
I checked the code and you need to send a SIGUSR1 signal to the e750-mcu program to broadcast information to the MCU
killall -10 /usr/bin/e750-mcu
Ah I see I will make a crontab to run that thanks.
@luochongjun I also notice that the display says āNo Internetā even though it is connected what is in charge of telling the program that there is internet?
Looks like if I run killall -10 /usr/bin/e750-mcu
every minute it will cause the procress to crash
Sun Apr 23 01:50:56 2023 daemon.info procd: Instance e750_mcu::instance1 s in a crash loop 6 crashes, 55 seconds since last crash
Turns out I have to use kill -s USR1 $(pidof /usr/bin/e750-mcu)
You can run the e750-mcu program directly and observe the error location.
Thanks I have solve the process crash issue but I am wondering where does e750-mcu
get the information from to display the āNo Internetā message on the screen?
You can obtain the status indication of mwan3 to send to mcu.
mwan3 status
Thanks what about the mobile signal strength currently it always shows 4 bars.
