GL-E750V2 IMEI CHANGE
Hi everyone, I have a question about the GL-E750V2 (MUDI). I hope to get some answers here.
So, how can I change/repair my IMEI on the GL-E750V2 ?
Just by command? For example:
AT+EGMR=1,7,"IMEI"
Or do I need to ad an external software package?
In this case:
Yep, just by running the correct AT command via web GUI. Make sure to write down the original IMEI.
Thank you🤝 Can I run "Perfect Privacy" as my VPN provider?
If they support OpenVPN or WireGuard - yes.
