I recently purchased the GL.iNet 4G Smart Router from Amazon as a couple reviews mentioned a Google Fi sim should work in the device. Unfortunately it doesn’t seem to be connecting, even with manually inputing the APN. Has anyone successfully set this up that can assist?
Make sure you have set the pin in the UI if there is one on the simcard.
