GL.iNet 6416 +5 and +3.3 volt wrong way arround!
Just be careful when doing some DIY on the GL.iNet 6416!
The +5 and and +3.3 are drawn the wrong way around in the picture shown on the gl-inet site!
(found here: Overview - GL.iNet Docs )
Thanks. Just corrected
Is it possible to power the unit through the 5 volt pin and serial GND instead of using the USB?
Or… Is there any other way to power the board instead of using the micro/USB.
Yes for 6416 you can power it up using the 5v pin or using the usb-A
