Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.000000] Linux version 4.9.120 (lancer@gl-inet) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7258-5eb055306f) ) #0 Thu Aug 16 07:51:15 2018
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Determined physical RAM map:
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Zone ranges:
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Movable zone start for each node
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Early memory node ranges
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 805237b4, node_mem_map 81000020
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.000000] Kernel command line: board=GL-AR750S console=ttyS0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env),64k(art)ro,2048k(kernel),13052k(reserved);spi0.1:-(ubi) rootfstype=squashfs noinitrd
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Memory: 124164K/131072K available (3816K kernel code, 163K rwdata, 900K rodata, 232K init, 219K bss, 6908K reserved, 0K cma-reserved)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] NR_IRQS:51
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] Clocks: CPU:775.000MHz, DDR:650.000MHz, AHB:258.333MHz, Ref:25.000MHz
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.008223] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.071045] pid_max: default: 32768 minimum: 301
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.076000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.082975] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.092756] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.103160] futex hash table entries: 256 (order: -1, 3072 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.110632] NET: Registered protocol family 16
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.116617] MIPS: machine is GL-AR750S
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 0.360128] registering PCI controller with io_map_base unset
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.382200] usbcore: registered new interface driver usbfs
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.388097] usbcore: registered new interface driver hub
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.393749] usbcore: registered new device driver usb
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.399271] i2c-gpio i2c-gpio.0: using pins 5 (SDA) and 21 (SCL)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.405801] PCI host bridge to bus 0000:00
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.410156] pci_bus 0000:00: root bus resource [mem 0x12000000-0x13ffffff]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.417394] pci_bus 0000:00: root bus resource [io 0x0001]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.423273] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.430424] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.438804] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
Wed Jun 19 16:42:49 2019 kern.err kernel: [ 0.438813] pci 0000:00:00.0: invalid calibration data
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.444242] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.444289] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.444354] pci 0000:00:00.0: supports D1
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.444361] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.444543] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.444567] pci 0000:00:00.0: BAR 0: assigned [mem 0x12000000-0x121fffff 64bit]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.452312] pci 0000:00:00.0: BAR 6: assigned [mem 0x12200000-0x1220ffff pref]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.459928] pci 0000:00:00.0: using irq 40 for pin 1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.468511] clocksource: Switched to clocksource MIPS
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.474749] NET: Registered protocol family 2
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.480167] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.487527] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.494269] TCP: Hash tables configured (established 1024 bind 1024)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.501055] UDP hash table entries: 256 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.507220] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.514077] NET: Registered protocol family 1
Wed Jun 19 16:42:49 2019 kern.debug kernel: [ 0.518729] PCI: CLS 0 bytes, default 32
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 0.521126] Crashlog allocated RAM at address 0x3f00000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.527594] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.540432] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.546577] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.565607] io scheduler noop registered
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.569780] io scheduler deadline registered (default)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.575564] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.584445] console [ttyS0] disabled
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.608285] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.617381] console [ttyS0] enabled
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.624939] bootconsole [early0] disabled
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 0.638832] m25p80 spi0.0: found w25q128, expected m25p80
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.653650] m25p80 spi0.0: w25q128 (16384 Kbytes)
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.658555] 5 cmdlinepart partitions found on MTD device spi0.0
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.664666] Creating 5 MTD partitions on “spi0.0”:
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.669634] 0x000000000000-0x000000040000 : “u-boot”
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.676399] 0x000000040000-0x000000050000 : “u-boot-env”
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.683604] 0x000000050000-0x000000060000 : “art”
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.690221] 0x000000060000-0x000000260000 : “kernel”
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.697045] 0x000000260000-0x000000f1f000 : “reserved”
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.704526] spi-nand: Giga SPI NAND was found.
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 0.709172] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.717356] 1 cmdlinepart partitions found on MTD device spi0.1
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.723505] Creating 1 MTD partitions on “spi0.1”:
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 0.728459] 0x000000000000-0x000008000000 : “ubi”
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 1.182134] found bad block 7fe0000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 1.186362] libphy: Fixed MDIO Bus: probed
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 1.200318] switch0: Atheros AR8337 rev. 2 switch registered on ag71xx-mdio.0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 1.924585] libphy: ag71xx_mdio: probed
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.559957] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd036, driver=Atheros AR8216/AR8236/AR8316]
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.571512] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.578029] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.584812] ehci-pci: EHCI PCI platform driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.589573] usbcore: registered new interface driver usbtest
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.595464] usbcore: registered new interface driver usb_ehset_test
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 2.601956] random: fast init done
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.605534] usbcore: registered new interface driver lvs
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.612510] NET: Registered protocol family 10
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.621202] NET: Registered protocol family 17
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.625840] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 2.639341] 8021q: 802.1Q VLAN Support v1.8
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 2.648914] UBI: auto-attach mtd5
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 2.652368] ubi0: attaching mtd5
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.319282] ubi0: scanning is finished
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.374382] ubi0: attached mtd5 (name “ubi”, size 128 MiB)
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.380096] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.387194] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.394213] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.401405] ubi0: good PEBs: 1023, bad PEBs: 1, corrupted PEBs: 0
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.407695] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.415161] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 1751850999
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.424594] ubi0: available PEBs: 0, total reserved PEBs: 1023, PEBs reserved for bad PEB handling: 19
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.434273] ubi0: background thread “ubi_bgt0d” started, PID 352
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 7.443889] block ubiblock0_0: created from ubi0:0(rootfs)
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 7.449613] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 7.456800] hctosys: unable to open rtc device (rtc0)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 7.481071] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 7.489731] Freeing unused kernel memory: 232K
Wed Jun 19 16:42:49 2019 kern.warn kernel: [ 7.494318] This architecture does not have kernel memory protection.
Wed Jun 19 16:42:49 2019 user.info kernel: [ 8.426169] init: Console is alive
Wed Jun 19 16:42:49 2019 user.info kernel: [ 8.429966] init: - watchdog -
Wed Jun 19 16:42:49 2019 user.info kernel: [ 11.321414] kmodloader: loading kernel modules from /etc/modules-boot.d/
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.520820] exFAT: Version 1.2.9
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 11.559927] SCSI subsystem initialized
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.568686] ehci-platform: EHCI generic platform driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.574155] ehci-platform ehci-platform.0: EHCI Host Controller
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.580462] ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.590938] ehci-platform ehci-platform.0: irq 48, io mem 0x1b000000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.618551] ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.625362] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.632405] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.639873] usb usb1: Product: EHCI Host Controller
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.644907] usb usb1: Manufacturer: Linux 4.9.120 ehci_hcd
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.650585] usb usb1: SerialNumber: ehci-platform.0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.656308] hub 1-0:1.0: USB hub found
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.660439] hub 1-0:1.0: 1 port detected
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.664775] ehci-platform ehci-platform.1: EHCI Host Controller
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.671090] ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.681575] ehci-platform ehci-platform.1: irq 49, io mem 0x1b400000
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.708549] ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.715352] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.722390] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.729859] usb usb2: Product: EHCI Host Controller
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.734892] usb usb2: Manufacturer: Linux 4.9.120 ehci_hcd
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.740571] usb usb2: SerialNumber: ehci-platform.1
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.746284] hub 2-0:1.0: USB hub found
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.750417] hub 2-0:1.0: 1 port detected
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.757302] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.765086] ohci-platform: OHCI generic platform driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.772952] uhci_hcd: USB Universal Host Controller Interface driver
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.783718] usbcore: registered new interface driver usb-storage
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 11.791782] usbcore: registered new interface driver uas
Wed Jun 19 16:42:49 2019 user.info kernel: [ 11.797909] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Wed Jun 19 16:42:49 2019 user.info kernel: [ 11.807658] init: - preinit -
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 12.738761] usb 2-1: new high-speed USB device number 2 using ehci-platform
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.010376] usb 2-1: New USB device found, idVendor=05e3, idProduct=0618
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.017321] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.024717] usb 2-1: Product: USB2.0 Hub
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.080757] hub 2-1:1.0: USB hub found
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.088570] hub 2-1:1.0: 4 ports detected
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 13.108839] random: procd: uninitialized urandom read (4 bytes read)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.484703] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.578534] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.732848] usb 2-1.1: New USB device found, idVendor=05e3, idProduct=0752
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.739984] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.747544] usb 2-1.1: Product: USB Storage
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.751873] usb 2-1.1: Manufacturer: Generic
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.757562] usb-storage 2-1.1:1.0: USB Mass Storage device detected
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 13.764766] scsi host0: usb-storage 2-1.1:1.0
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 14.520178] eth0: link up (1000Mbps/Full duplex)
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 14.525152] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 14.840213] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 14.853392] sd 0:0:0:0: [sda] Attached SCSI removable disk
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 16.749955] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 471
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.019953] UBIFS (ubi0:1): recovery needed
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.577629] UBIFS (ubi0:1): recovery completed
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.582323] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.590430] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.600679] UBIFS (ubi0:1): FS size: 114786304 bytes (109 MiB, 904 LEBs), journal size 5713920 bytes (5 MiB, 45 LEBs)
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.611640] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
Wed Jun 19 16:42:49 2019 kern.notice kernel: [ 17.618472] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 03074A4B-967F-4BC6-B829-A1D7820F4153, small LPT model
Wed Jun 19 16:42:49 2019 user.info kernel: [ 17.669570] mount_root: switching to ubifs overlay
Wed Jun 19 16:42:49 2019 user.warn kernel: [ 17.753333] urandom-seed: Seeding with /etc/urandom.seed
Wed Jun 19 16:42:49 2019 kern.info kernel: [ 17.969347] eth0: link down
Wed Jun 19 16:42:49 2019 user.info kernel: [ 17.982436] procd: - early -
Wed Jun 19 16:42:49 2019 user.info kernel: [ 17.985496] procd: - watchdog -
Wed Jun 19 16:42:49 2019 user.info kernel: [ 18.636611] procd: - watchdog -
Wed Jun 19 16:42:49 2019 user.info kernel: [ 18.641080] procd: - ubus -
