gl inet ax1800 completely locked out
hello i was in the process of setup firewall the kill switch and vpn on my new router something went wrong and i am completely locked out i to the point that i cannot even reset it with the button what do is there a solution or am i using a $125 paper weight now? Any help will be greatly appreciated. thanks in advance
When trying the reset button, make sure your holding it down for at least 10 seconds.
You can also try resetting via uboot. Check this post
Usually, when you cannot access the router management panel, there are two simple ways to restore the factory settings.
  1. Try to restore the factory settings through the external reset physical button.
  2. Reinstall the firmware through U-Boot.(Note: A computer with an Ethernet port and an Ethernet cable are required. Set the computer's IP address to 192.168.1.2)
I agree with the above statement. You can refer to the DOCS document link on the official website for troubleshooting.
