GL-iNet AX1800 OpenWrt firmware
Yes, I’m using it. This is GL.iNet’s repository.
That’s awesome!:smile:
Since it’s from the GL repo, does that mean the router will still have the GL.iNet firmware page, or will it just be barebones OpenWRT?
Barebones OpenWrt:
NAME="OpenWrt"
VERSION="21.02-SNAPSHOT"
ID="openwrt"
ID_LIKE="lede openwrt"
PRETTY_NAME="OpenWrt 21.02-SNAPSHOT"
VERSION_ID="21.02-snapshot"
HOME_URL="https://openwrt.org/"
BUG_URL="https://bugs.openwrt.org/"
SUPPORT_URL="https://forum.openwrt.org/"
BUILD_ID="r16273+112-378769b555"
OPENWRT_BOARD="ipq807x/ipq60xx"
OPENWRT_ARCH="arm_cortex-a7"
OPENWRT_TAINTS="no-all override"
OPENWRT_DEVICE_MANUFACTURER="OpenWrt"
OPENWRT_DEVICE_MANUFACTURER_URL="https://openwrt.org/"
OPENWRT_DEVICE_PRODUCT="Generic"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="OpenWrt 21.02-SNAPSHOT r16273+112-378769b555"
Do you have a link? as i know have Serial UART connected to the board so i can not long test but cap logs live too.
The version I’m using is highly customized with proprietary software, but if you’re looking to test a vanilla/stock version, I can build it for you if that’s what you’re requesting. It’s easy to do.
Sure, i am compiling a version myself to test however its on a J4105 cpu in a VM so it can take 3 days to compile.
So i am willing to test any build for now just to see if the Wireless issue is solved from the other builds i have tested thats landed me in a reboot loop.
No worries…
Hot off the press:
https://sokoloski.ca/openwrt-gl-ax1800/
This is fantastic start @darryl
I am getting the following error string when trying to update the software repository. Any pointers?
Can this be flashed directly from the GL.iNet Admin Panel > Upgrade > Local Upgrade?
If so, which of the 3 files can be flashed? Thanks! Want to try a recent OpenWRT for Flint.
Thanks!
Hi bud just tried yours, It boots ok but adding a second SSID to either radio causes a reboot loop.
[   21.743149] QC Image Version: QC_IMAGE_VERSION_STRING=WLAN.HK.2.5.0.1-01100-Q        CAHKSWPL_SILICONZ-1
[   21.743149] Image Variant : IMAGE_VARIANT_STRING=6018.wlanfw.evalQ
[   21.743149]
[   21.743149] phyrf_reset.c:1131 Assertion (boardOpFlags == WHAL_WLAN_11AG_CAPA        BILITY) || ((boardOpFlags == WHALparam0 :zero, param1 :zero, param2 :zero.
[   21.743149] Thread ID      : 0x00000068  Thread name    : WLAN RT0  Process I        D     : 0
[   21.743149] Register:
[   21.743149] SP : 0x4bb6e720
[   21.743149] FP : 0x4bb6e728
[   21.743149] PC : 0x4ac8d44c
[   21.743149] SSR : 0x00000008
[   21.743149] BADVA : 0x00020000
[   21.743149] LR : 0x4ac8cbe8
[   21.743149]
[   21.743149] Stack Dump
[   21.743149] from : 0x4bb6e720
[   21.743149] to   : 0x4bb6eec0
[   21.743149]
[   21.795476] remoteproc remoteproc0: crash detected in cd00000.qcom_q6v5_wcss:        type fatal error
[   21.817827] remoteproc remoteproc0: handling crash #1 in cd00000.qcom_q6v5_wc        ss
[   21.826141] remoteproc remoteproc0: recovering cd00000.qcom_q6v5_wcss
[   22.634381] ath11k c000000.wifi: failed to synchronize setup for vdev 1 start        : -110
[   22.634419] ath11k c000000.wifi: failed to start vdev 1 addr 94:83:c4:16:e5:9        e on freq 5300: -110
[   27.644368] br-lan: port 1(eth1) entered forwarding state
[   28.204359] br-lan: port 5(wlan1) entered forwarding state
[   29.184375] ath11k c000000.wifi: bss channel survey timed out
[   31.824372]  9eb8235c:9eb827bc: intent request timed out
[   31.824404] qcom_glink_ssr 9eb8235c:9eb827bc.glink_ssr.-1.-1: failed to send cleanup message
[   32.824375] qcom_glink_ssr 9eb8235c:9eb827bc.glink_ssr.-1.-1: timeout waiting for cleanup done message
[   32.824423] ath11k c000000.wifi: ATH11K Driver Stats
[   32.824423]
[   32.824423] Backpressure Stats
[   32.824423] ==================
[   32.824423] No Ring Backpressure stats received
[   32.824423]
[   32.824423]
[   32.832594] ath11k c000000.wifi: Last interrupt received for each CE:
[   32.852642] ath11k c000000.wifi: CE_id 0 pipe_num 0 15590ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   32.859063] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before      15600ms,         tot_sched_cnt                    4,     last_exec_before      15600ms,  tot_exec_cnt                    4
[   32.869318] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.886157] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.902911] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.919665] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.936418] ath11k c000000.wifi: CE_id 1 pipe_num 1 11340ms before, sched_delay_gt_500US 1, exec_delay_gt_500US 0
[   32.953158] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before      11350ms,         tot_sched_cnt                   26,     last_exec_before      11350ms,  tot_exec_cnt                   27
[   32.963377] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.980172] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   32.996926] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.013676] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.030437] ath11k c000000.wifi: CE_id 2 pipe_num 2 11390ms before, sched_delay_gt_500US 1, exec_delay_gt_500US 0
[   33.047176] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before      11410ms,         tot_sched_cnt                   48,     last_exec_before      11410ms,  tot_exec_cnt                   49
[   33.057341] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.074179] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.090935] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.107686] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.124440] ath11k c000000.wifi: CE_id 3 pipe_num 3 11490ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.141180] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before      11500ms,         tot_sched_cnt                   25,     last_exec_before      11500ms,  tot_exec_cnt                   25
[   33.151348] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.168189] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.184982] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.201701] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.218453] ath11k c000000.wifi: CE_id 5 pipe_num 5 4294700506ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.235195] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.245708] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.262636] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.279387] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.296141] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.312893] ath11k c000000.wifi: CE_id 7 pipe_num 7 4120ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.329634] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before       4140ms,         tot_sched_cnt                   53,     last_exec_before       4140ms,  tot_exec_cnt                   53
[   33.339803] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.356561] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.373311] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.390064] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.406817] ath11k c000000.wifi: CE_id 9 pipe_num 9 4294700696ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.423558] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.434074] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.451001] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.467755] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.484510] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.501261] ath11k c000000.wifi: CE_id 10 pipe_num 10 4294700786ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.518004] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.528865] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.545620] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.562372] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.579125] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.595921] ath11k c000000.wifi: CE_id 11 pipe_num 11 4294700886ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
[   33.612627] ath11k c000000.wifi: ce_time_dur_100US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.623489] ath11k c000000.wifi: ce_time_dur_200US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.640242] ath11k c000000.wifi: ce_time_dur_300US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.656993] ath11k c000000.wifi: ce_time_dur_400US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.673747] ath11k c000000.wifi: ce_time_dur_500US,   last_sched_before          0ms,         tot_sched_cnt                    0,     last_exec_before          0ms,  tot_exec_cnt                    0
[   33.690496] ath11k c000000.wifi:
[   33.690496] Last interrupt received for each group:
[   33.707235] ath11k c000000.wifi: group_id 0 16320ms before
[   33.715302] ath11k c000000.wifi: group_id 1 16330ms before
[   33.720674] ath11k c000000.wifi: group_id 2 4294701006ms before
[   33.726152] ath11k c000000.wifi: group_id 3 4294701016ms before
[   33.731959] ath11k c000000.wifi: group_id 4 12170ms before
[   33.737870] ath11k c000000.wifi: group_id 5 12110ms before
[   33.743417] ath11k c000000.wifi: group_id 6 4294701026ms before
[   33.748895] ath11k c000000.wifi: group_id 7 4294701036ms before
[   33.754712] ath11k c000000.wifi: group_id 8 4294701046ms before
[   33.760606] ath11k c000000.wifi: group_id 9 4294701046ms before
[   33.766516] ath11k c000000.wifi: group_id 10 4294701056ms before
[   33.772414] ath11k c000000.wifi: dst srng id 0 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701056ms
[   33.778681] ath11k c000000.wifi: dst srng id 1 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701066ms
[   33.789183] ath11k c000000.wifi: dst srng id 2 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701076ms
[   33.799947] ath11k c000000.wifi: dst srng id 3 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701086ms
[   33.810710] ath11k c000000.wifi: dst srng id 4 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16420ms
[   33.821475] ath11k c000000.wifi: src srng id 5 hp 0, reap_hp 248, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701106ms
[   33.831898] ath11k c000000.wifi: src srng id 8 hp 0, reap_hp 2550, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701116ms
[   33.843962] ath11k c000000.wifi: dst srng id 9 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701126ms
[   33.855856] ath11k c000000.wifi: src srng id 16 hp 0, reap_hp 4088, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701146ms
[   33.866444] ath11k c000000.wifi: src srng id 17 hp 0, reap_hp 4088, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701156ms
[   33.878599] ath11k c000000.wifi: src srng id 18 hp 0, reap_hp 4088, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701166ms
[   33.890662] ath11k c000000.wifi: src srng id 24 hp 0, reap_hp 248, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701176ms
[   33.902727] ath11k c000000.wifi: dst srng id 25 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701186ms
[   33.914794] ath11k c000000.wifi: src srng id 32 hp 16, reap_hp 12, cur tp 16, cached tp 16 last tp 12 napi processed before 16660ms
[   33.925732] ath11k c000000.wifi: src srng id 35 hp 108, reap_hp 104, cur tp 108, cached tp 108 last tp 104 napi processed before 12290ms
[   33.937278] ath11k c000000.wifi: src srng id 36 hp 76, reap_hp 72, cur tp 76, cached tp 76 last tp 72 napi processed before 12650ms
[   33.949777] ath11k c000000.wifi: src srng id 39 hp 0, reap_hp 92, cur tp 96, cached tp 96 last tp 96 napi processed before 4760ms
[   33.961321] ath11k c000000.wifi: src srng id 41 hp 0, reap_hp 124, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701246ms
[   33.973129] ath11k c000000.wifi: src srng id 57 hp 50, reap_hp 50, cur tp 54, cached tp 54 last tp 54 napi processed before 12370ms
[   33.985108] ath11k c000000.wifi: src srng id 58 hp 96, reap_hp 96, cur tp 100, cached tp 100 last tp 100 napi processed before 12350ms
[   33.996738] ath11k c000000.wifi: src srng id 61 hp 1020, reap_hp 1020, cur tp 0, cached tp 0 last tp 0 napi processed before 16740ms
[   34.008891] ath11k c000000.wifi: src srng id 66 hp 1020, reap_hp 1020, cur tp 0, cached tp 0 last tp 0 napi processed before 16750ms
[   34.020962] ath11k c000000.wifi: dst srng id 81 tp 108, cur hp 108, cached hp 108 last hp 108 napi processed before 12420ms
[   34.032848] ath11k c000000.wifi: dst srng id 82 tp 200, cur hp 200, cached hp 200 last hp 200 napi processed before 12390ms
[   34.043698] ath11k c000000.wifi: dst srng id 85 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701326ms
[   34.054812] ath11k c000000.wifi: dst srng id 90 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701346ms
[   34.065922] ath11k c000000.wifi: src srng id 104 hp 65532, reap_hp 65532, cur tp 0, cached tp 0 last tp 0 napi processed before 16820ms
[   34.076773] ath11k c000000.wifi: src srng id 105 hp 0, reap_hp 504, cur tp 0, cached tp 0 last tp 0 napi processed before 4294701366ms
[   34.088665] ath11k c000000.wifi: dst srng id 106 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16700ms
[   34.100816] ath11k c000000.wifi: dst srng id 107 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16710ms
[   34.111493] ath11k c000000.wifi: dst srng id 108 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701396ms
[   34.121996] ath11k c000000.wifi: dst srng id 109 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16730ms
[   34.132848] ath11k c000000.wifi: src srng id 128 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 16740ms
[   34.143445] ath11k c000000.wifi: src srng id 130 hp 254, reap_hp 254, cur tp 0, cached tp 0 last tp 0 napi processed before 16760ms
[   34.155335] ath11k c000000.wifi: src srng id 132 hp 16, reap_hp 16, cur tp 18, cached tp 18 last tp 18 napi processed before 12600ms
[   34.166963] ath11k c000000.wifi: dst srng id 133 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16780ms
[   34.179114] ath11k c000000.wifi: dst srng id 134 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701466ms
[   34.189618] ath11k c000000.wifi: src srng id 135 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 16810ms
[   34.200471] ath11k c000000.wifi: src srng id 143 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 16810ms
[   34.212450] ath11k c000000.wifi: src srng id 145 hp 254, reap_hp 254, cur tp 0, cached tp 0 last tp 0 napi processed before 16820ms
[   34.224430] ath11k c000000.wifi: src srng id 147 hp 116, reap_hp 116, cur tp 118, cached tp 118 last tp 118 napi processed before 12600ms
[   34.236062] ath11k c000000.wifi: dst srng id 148 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 16850ms
[   34.248559] ath11k c000000.wifi: dst srng id 149 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 4294701536ms
[   34.259150] ath11k c000000.wifi: src srng id 150 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 16870ms
[   34.270019] ------------[ cut here ]------------
[   34.281957] kernel BUG at /home/dsokoloski/build/gl-infra-builder-ax1800/wlan-ap/openwrt/build_dir/target-arm_cortex-a7_musl_eabi/linux-ipq807x_ipq60xx/backports-20210222_001-4.4.60-b157d2276/drivers/net/wireless/ath/ath11k/core.c:1120!
[   34.286674] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[   34.307564] Modules linked in: iptable_nat nf_nat_ipv4 ath11k_ahb ath11k_pci ath11k nf_conntrack_ipv6 nf_conntrack_ipv4 mac80211 ipt_REJECT ipt_MASQUERADE cfg80211 xt_time xt_tcpudp xt_state xt_nat xt_multiport xt_mark xt_mac xt_limit xt_id xt_conntrack xt_comment xt_TCPMSS xt_REDIRECT xt_LOG ppp_async nf_reject_ipv4 nf_nat_redirect nf_nat_masquerade_ipv4 nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_rtcache nf_conntrack iptable_mangle iptable_filter ip_tables compat qca_nss_wifi_meshmgr qca_nss_pppoe pppoe pppox ppp_generic slhc qca_nss_bridge_mgr qca_nss_vlan nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 bonding qca_nss_drv qca_nss_dp qca_ssdk xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm phy_msm_ssusb_qmp phy_msm_qusb gpio_button_hotplug usbcore nls_base usb_common
[   34.387939] CPU: 1 PID: 1966 Comm: kworker/1:3 Not tainted 4.4.60 #0
[   34.388207] Hardware name: Generic DT based system
[   34.394638] Workqueue: events rproc_crash_handler_work
[   34.404343] task: 9d790480 ti: 97fec000 task.ti: 97fec000
[   34.404481] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
[   34.409855] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
[   34.415902] pc : [<7f49e068>]    lr : [<7f4a075c>]    psr: 60000013
[   34.415902] sp : 97fede28  ip : 00000000  fp : 9dfea028
[   34.422506] r10: 807e2320  r9 : 9dfea264  r8 : 00000000
[   34.433692] r7 : 807104c0  r6 : 9e59b010  r5 : 807104c0  r4 : 9bbd092c
[   34.438903] r3 : 00000000  r2 : dc8ba63c  r1 : 9eb4a324  r0 : 00000079
[   34.445503] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[   34.452013] Control: 10c0383d  Table: 578ac06a  DAC: 00000055
[   34.459214] Process kworker/1:3 (pid: 1966, stack limit = 0x97fec210)
[   34.465120] Stack: (0x97fede28 to 0x97fee000)
[   34.471541] de20:                   8087db14 9bbd192c 00000000 fffffffd 00000000 80044bd0
[   34.475888] de40: 80821c38 00000000 807104c0 ffffffff 9dfea028 80044ec4 00000000 97fede6c
[   34.484048] de60: 00000000 9dfea378 9dfea204 00000001 9dfea000 80044ef8 00000000 80338b64
[   34.492208] de80: 9dfea22c 80428d44 9dfea22c 9dfea264 9dfea000 9dfea22c 9dfea1c0 8042a890
[   34.500368] dea0: 00000001 803389f8 806f01ec 8070f5cc 9dfc5d40 00000000 0108f168 9dfea22c
[   34.508528] dec0: 9dfea264 00000003 9dfea22c 9dfea1c0 9dfea264 807e2320 9eb4cac0 8042abc8
[   34.516687] dee0: 8042aa9c 9dfea22c 9be5cd00 9eb4cac0 9eb4ff00 00000000 00000000 807e2320
[   34.524848] df00: 9eb4cac0 8003eb60 9eb4cac0 9eb4cac0 00000008 9be5cd00 9be5cd18 9eb4cac0
[   34.533007] df20: 00000008 9eb4cad4 97fec000 807e2320 9eb4cac0 8003efe0 807de100 9be5cd00
[   34.541166] df40: 8003ecf8 00000000 9d56d940 9be5cd00 8003ecf8 00000000 00000000 00000000
[   34.549326] df60: 00000000 800440bc 97fedd10 00000000 00000000 9be5cd00 00000000 00000000
[   34.557486] df80: 97fedf80 97fedf80 00000000 00000000 97fedf90 97fedf90 97fedfac 9d56d940
[   34.565645] dfa0: 80043fcc 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
[   34.573805] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   34.581966] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[   34.590194] [<7f49e068>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044bd0>] (notifier_call_chain+0x2c/0x70)
[   34.598292] [<80044bd0>] (notifier_call_chain) from [<80044ec4>] (__blocking_notifier_call_chain+0x48/0x64)
[   34.608532] [<80044ec4>] (__blocking_notifier_call_chain) from [<80044ef8>] (blocking_notifier_call_chain+0x18/0x20)
[   34.618084] [<80044ef8>] (blocking_notifier_call_chain) from [<80428d44>] (rproc_stop+0x2c/0xc4)
[   34.628844] [<80428d44>] (rproc_stop) from [<8042a890>] (rproc_trigger_recovery+0x4c/0x258)
[   34.637610] [<8042a890>] (rproc_trigger_recovery) from [<8042abc8>] (rproc_crash_handler_work+0x12c/0x1bc)
[   34.645686] [<8042abc8>] (rproc_crash_handler_work) from [<8003eb60>] (process_one_work+0x220/0x3b8)
[   34.655406] [<8003eb60>] (process_one_work) from [<8003efe0>] (worker_thread+0x2e8/0x4d0)
[   34.664691] [<8003efe0>] (worker_thread) from [<800440bc>] (kthread+0xf0/0xf8)
[   34.672764] [<800440bc>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
[   34.679880] Code: eb371815 e3500000 0affffe9 ea000000 (e7f001f2)
[   34.687082] ---[ end trace c6fd428268c9f816 ]---
[   34.696052] Kernel panic - not syncing: Fatal exception
[   34.697931] CPU2: stopping
[   34.702876] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
[   34.705657] Hardware name: Generic DT based system
[   34.712867] [<8001f5c4>] (unwind_backtrace) from [<8001b914>] (show_stack+0x10/0x14)
[   34.717557] [<8001b914>] (show_stack) from [<8025c8c0>] (dump_stack+0x8c/0xa0)
[   34.725455] [<8025c8c0>] (dump_stack) from [<8001e520>] (handle_IPI+0x104/0x190)
[   34.732486] [<8001e520>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
[   34.740037] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
[   34.747412] Exception stack(0x9e483f88 to 0x9e483fd0)
[   34.754963] 3f80:                   00000001 00000000 00000000 8000b400 9e482000 807de4a0
[   34.760003] 3fa0: 80689204 00000000 00000000 807d830c 9e483fe0 807de4a8 60000013 9e483fd8
[   34.768161] 3fc0: 800191d4 800191d8 60000013 ffffffff
[   34.776318] [<8000a4c0>] (__irq_svc) from [<800191d8>] (arch_cpu_idle+0x34/0x50)
[   34.781359] [<800191d8>] (arch_cpu_idle) from [<8006348c>] (cpu_startup_entry+0x154/0x228)
[   34.788824] [<8006348c>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
[   34.796890] CPU3: stopping
[   34.803742] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
[   34.806525] Hardware name: Generic DT based system
[   34.813732] [<8001f5c4>] (unwind_backtrace) from [<8001b914>] (show_stack+0x10/0x14)
[   34.818424] [<8001b914>] (show_stack) from [<8025c8c0>] (dump_stack+0x8c/0xa0)
[   34.826321] [<8025c8c0>] (dump_stack) from [<8001e520>] (handle_IPI+0x104/0x190)
[   34.833353] [<8001e520>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
[   34.840905] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
[   34.848280] Exception stack(0x9e485f88 to 0x9e485fd0)
[   34.855831] 5f80:                   00000001 00000000 00000000 8000b400 9e484000 807de4a0
[   34.860871] 5fa0: 80689204 00000000 00000000 807d830c 9e485fe0 807de4a8 00000000 9e485fd8
[   34.869029] 5fc0: 800191d4 800191d8 60000013 ffffffff
[   34.877184] [<8000a4c0>] (__irq_svc) from [<800191d8>] (arch_cpu_idle+0x34/0x50)
[   34.882224] [<800191d8>] (arch_cpu_idle) from [<8006348c>] (cpu_startup_entry+0x154/0x228)
[   34.889690] [<8006348c>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
[   34.897758] CPU0: stopping
[   34.904609] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
[   34.907393] Hardware name: Generic DT based system
[   34.914600] [<8001f5c4>] (unwind_backtrace) from [<8001b914>] (show_stack+0x10/0x14)
[   34.919291] [<8001b914>] (show_stack) from [<8025c8c0>] (dump_stack+0x8c/0xa0)
[   34.927189] [<8025c8c0>] (dump_stack) from [<8001e520>] (handle_IPI+0x104/0x190)
[   34.934221] [<8001e520>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
[   34.941774] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
[   34.949149] Exception stack(0x807ddf50 to 0x807ddf98)
[   34.956697] df40:                                     00000001 00000000 00000000 8000b400
[   34.961740] df60: 807dc000 807de4a0 80689204 00000000 00000000 807d830c 807ddfa8 807de4a8
[   34.969898] df80: 60000013 807ddfa0 800191d4 800191d8 60000013 ffffffff
[   34.978056] [<8000a4c0>] (__irq_svc) from [<800191d8>] (arch_cpu_idle+0x34/0x50)
[   34.984482] [<800191d8>] (arch_cpu_idle) from [<8006348c>] (cpu_startup_entry+0x154/0x228)
[   34.992125] [<8006348c>] (cpu_startup_entry) from [<807a2d28>] (start_kernel+0x430/0x43c)
[   35.000243] The reading for sensor 4 is 0x002041d1
[   35.008480] Couldn't get reading for sensor 5
[   35.013121] The reading for sensor 7 is 0x002071c7
[   35.017596] Couldn't get reading for sensor 8
[   35.022234] The reading for sensor 13 is 0x0022d1d4
[   35.026709] Couldn't get reading for sensor 14
[   35.031349] The reading for sensor 15 is 0x0020f1cd
[   35.645068] Rebooting in 3 seconds.
Not blaming you at all, as its doing this on all images i flash unless its the stock firmware. All images are flashed via uboot too.
Edit: found the issue it doesn’t like 160MHz mode at all.
It does not support.
Right i managed to compile everything and added everything i needed in. Performing right now nicely with SQM enabled i am not seeing 900ms+ on upstream during bufferbloat tests.
|Model|GL Technologies, Inc. AX1800|
|Architecture|ARMv7 Processor rev 4 (v7l)|
|Target Platform|ipq807x/ipq60xx|
|Firmware Version|OpenWrt 21.02-SNAPSHOT r16273+112-378769b555 / LuCI openwrt-22.03 branch git-21.284.67084-e4d24f0|
|Kernel Version|4.4.60|
|Local Time|2022-04-22 11:45:51|
|Uptime|0h 45m 34s|
|Load Average|0.01, 0.02, 0.00|
Total Packet Loss: 0.02%
Upload Packet Loss: 0.01%
Download Packet Loss: 0.01%
Late Packet Rate: 0.28%
Average Latency: 19.48ms
Average Jitter: 2.35ms
Test Settings:
  Duration: 30 seconds
  Frequency: 300 pings/second
  Average Size: 1100 bytes
  Acceptable Delay: 50ms
Going to keep it online for a few days to see how it stacks up against the WRT32x its replacing.
Only thing now is to see if we can get Kernel 5.10 or even 5.15 on this router so i can then make qosify package for some ultimate bufferbloat free internet gaming.
@melskie the .img file is best to flash via Uboot and the .tar file can be done after in LUCI. You can flash the .img with GL WebGUI however if you wish the .tar will not work though.
Thank you! I’ll try this later.
Could you share your build with us @solidus1983?
Sure uploading it to Mega right now as my internet will not be able to handle the on slaught of people downloading from my webserver.
Just bare in mind it was a quick mash up of what i use personally but its less bloaty then the others but no as less bloaty as @darryl 's build.
There will be bugs in it though.
AX1800 Mega.nz Folder: 115 MB folder on MEGA
Is luci-app-sqm included on this build? I tried darryl’s build. But it doesnt have the sqm package included. Thanks!
Yes SQM and Cake is included in my build as well as other things like VPN’s etc.
I am plaining on resolving some bugs and will then make a new build after.
One word of warning do not upgrade any packages, install new ones yes but do not upgrade anything as that can cause issues.
Top man. I managed to install the build. Having smart queue management, BCP38 and a lightweight https server installed is fantastic. I noticed that you even went to the effort of including multiple language packages for the installed software. Thank you.
Just starting work on getting the bugs sorted out and then i will include the packages i normally do the for Linksys WRT32x.
Hopefully Gl-iNet can get it ported to stock openwrt kernel soon enough as its been solid for me tonight, no bufferbloat issues and no ram issues. Just solid performance.
Is AX1800 (Flint) still stuck with an ancient OpenWRT version? I looked at the forum messages and various firmware downloads/release notes, but that doesn’t mention any OpenWRT version updates.
